hatch or polyline in gdl
How can i write a Hatch or polyline in Gdl where I can add or delete Hotspots working with the object later on. (using common tools for Line/curve etc. would be brilliant if possible) ? Also I wander if its possibel to stretch just a part of an object in gdl (as the profile tool wher just the part between the two lines is streched bod not the parts outside. ) Or - is ther even a way to call a profile into an object. At least I tried but it didnt work.
1 Solution
This may help.
https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=43721
Go to post
2 Replies 2
This may help.
thank you!
