Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
hotspot for stairs created with stairmaker
alemanda
I wonder why in stair objects created with archistair the hotspot are not placed at the correct height.
Who knows?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
1 REPLY 1
rocorona
Do you mean Stairmaker? This is because they do not use the zzyzx value. It is "abandoned" at his default value (1 m), so the top hotspots are the same of the bottom ones, elevated to 1m. You can edit the "object height", but this only changes the HS height, with no effect to the stair. Why these basic objects are so poorly designed, without any editable hotspot? Mistery.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
