License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
how can I get the GDL model volume
leilei
I create three GROUPS in GDL 3D script,and each GROUP has different Complex model ,so I have a trouble how can I get a GROUP volume with them.What good function can be calculated in GDL 3D script
4 REPLIES 4
Nader Belal
Mentor
I would like to hear a solution for such problem too
Nader Belal
Mentor
@leilei
Just found your answer VOLUME3D() FUNCTION
Or in your GDL Manual - Non-Geometric Scripts --> The Properties Script --> VOLUME3D
Nader Belal
Mentor
@leilei
Sorry, my past suggestion is wrong in case that you need to calculate the volume in an script other than properties script
Nader Belal
Mentor
@leilei
I just read something in the ArchiCAD GDL reference guide that may interest you.
There is the possibility that you can use volume3D() in Property Script, use Text/data GDL add-on to export your results from within the Property Script, then use the same Add-on to import the data.
It's a long way.
