‎2009-10-20
06:00 AM
‎2023-05-24
11:56 AM
Rubia Torres
‎2009-10-21 11:49 PM
vfrontiers wrote:Duane, cool idea! It is sort of working for me, with a couple of snags. One is that the xox "sash" gets shoved over to the side in 3D view. See attached jpeg. Almost seems like AC is trying to show it 50% open in 3d, but there is no such toggle (I'm using a custom sash on the
You could do as described here(sashes only), but then change the SUBTYPE to Window Component. Then it will appear in the CUSTOM window menu of say a FIXED WINDOW... There you can use all the trims that are available to the standard Fixed window, but the Sash would appear as XOX.
‎2009-10-22 01:29 AM
‎2009-10-25 01:42 AM
