ā2011-06-04
04:15 PM
ā2023-05-24
12:36 PM
Rubia Torres
ā2011-06-04 05:31 PM
ā2011-06-05 05:17 AM
ā2011-06-06 05:54 PM
ā2011-06-07 01:34 AM
ahmed_hassan wrote:Read my post / links for the answer. You model these as part of the window...
Thanks NCornia the tutorial was very useful it open my mind to more secrets i was not in knowledge about but frame of window and sill shall i make it and save it as an object? or it can be shown automtically through GDL script
Best regards
ā2017-10-18 01:12 PM
ā2017-10-18 06:38 PM
igreere wrote:Last time I did this was years/versions ago... There you model a custom window flat 'on the ground' and save the elements from 3D as a window object - project elevation 0 represents the exterior wall surface. Elements above 0 are inside the wall, elements below 0 are outside/exterior.
I tried to do a custom window, I followed all the steps, but I do not know what is wrong with a distance/thickness somewhere, because, when I place the window, it looks like this (see attached photo).
ā2017-10-20 10:55 AM
