increasing font size in gdl 2d an 3d script windows, ac12
Hi!
Does anyone know how to increase the font size in gdl 2d an 3d script windows? After working for some hours on a gdl, it is a bit painfull to work with very small text.
I found in ArchicadWiki how to adjust the font size in dialog boxes (registry key), very usefull but does not cover the above.
Changing the font size in winvista does not have any effect.
The only way you can do it is to lowing down the monitor resolution.
Hope there is a way of doing this without having to lower resolutions etc.
my configuration: ac 12 on a win & vista pc.
Rod Jurich
ale-la wrote:
Hi!
Does anyone know how to increase the font size in gdl 2d an 3d script windows?/....
Alex,
this applies to all scripting windows of library parts.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
I'm not sure if this works on a Mac but it does on Windows.
With the cursor in the script just hold the CTRL key and scroll the mouse wheel.
I think this only affects how it looks on screen
Rod's method will affect how the script is printed if ever you print it.
Rod Jurich
Most important on screen, us older guys need all the help we can get
Rod Jurich
