ā2013-02-03 08:49 PM
ā2013-02-03 10:14 PM
ā2013-02-04 05:55 PM
ā2013-02-05 12:56 AM
ā2013-02-05 12:58 AM
ā2013-02-05 09:30 AM
ā2013-02-05 09:53 AM
ā2013-02-05 09:59 AM
EPS = 0.0001 OPERATION_CONVERT_POLYGON_AC_TO_GDL = 1 OPERATION_POINT_INSIDE_POLYGON = 2 OPERATION_LINE_LINE_INTERSECTION = 3 OPERATION_SEGMENT_SEGMENT_INTERSECTION = 4 OPERATION_INTERSECT_POLYGONS = 5 OPERATION_CALCULATE_POLYGON_AREA = 6 OPERATION_REVERSE_POLYGON = 7 INPUT_NO = 0 INPUT_FROM_PARAMETER = 1 INPUT_FROM_GDL_STACK = 2 OUTPUT_TO_PARAMETER = 1 OUTPUT_TO_GDL_STACK = 2 ! ============================================================================== bCalledFromScript = 0 if opcode = OPERATION_CONVERT_POLYGON_AC_TO_GDL then 100 ! Convert polygon: AC polygon -> GDL polygon if opcode = OPERATION_POINT_INSIDE_POLYGON then 200 ! Point inside polygon check if opcode = OPERATION_LINE_LINE_INTERSECTION then 300 ! Line-Line intersection if opcode = OPERATION_SEGMENT_SEGMENT_INTERSECTION then 400 ! Segment-Segment intersection if opcode = OPERATION_INTERSECT_POLYGONS then 500 ! Intersect polygons if opcode = OPERATION_CALCULATE_POLYGON_AREA then 600 ! Calculate polygon area if opcode = OPERATION_REVERSE_POLYGON then 700 ! Reverse polygon end 100: ! ============================================================================== ! Convert polygon: AC polygon -> GDL polygon ! OPERATION_CONVERT_POLYGON_AC_TO_GDL ! ============================================================================== ! Input: ! srcPolygon1: input source of polygon 1 (INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK) ! polygon1: input polygon ! result: output result (OUTPUT_TO_PARAMETER, OUTPUT_TO_GDL_STACK) ! GDL stack: coordX[1], coordY[1], arc[1], ... ! ! Output: ! polygon2: output polygon ! GDL stack: coordX[1], coordY[1], status[1], ... ! ============================================================================== gosub 101 if result = OUTPUT_TO_GDL_STACK then end end polygon2 101: if srcPolygon1 = INPUT_FROM_PARAMETER then numPnts = vardim1(polygon1) endif if srcPolygon1 = INPUT_FROM_GDL_STACK then numPnts = nsp/3 endif ac2gdl_lpa = 0 ac2gdJ = 1 for ac2gdlI = 1 to numPnts if srcPolygon1 = INPUT_FROM_PARAMETER then ac2gdl_px = polygon1[ac2gdlI][1] ac2gdl_py = polygon1[ac2gdlI][2] ac2gdl_pa = polygon1[ac2gdlI][3] endif if srcPolygon1 = INPUT_FROM_GDL_STACK then ac2gdl_px = get(1) ac2gdl_py = get(1) ac2gdl_pa = get(1) endif if ac2gdlI = 1 then ac2gdl_spx = ac2gdl_px ac2gdl_spy = ac2gdl_py endif if abs(ac2gdl_lpa) > EPS then ac2gdl_mx = (ac2gdl_px + ac2gdl_lpx) / 2 ac2gdl_my = (ac2gdl_py + ac2gdl_lpy) / 2 ac2gdl_ratio = 1 / 2 / tan (ac2gdl_lpa / 2) ac2gdl_cx = ac2gdl_mx - ac2gdl_ratio * (ac2gdl_py - ac2gdl_lpy) ! Arc center ac2gdl_cy = ac2gdl_my + ac2gdl_ratio * (ac2gdl_px - ac2gdl_lpx) if result = OUTPUT_TO_PARAMETER then polygon2[ac2gdJ][1] = ac2gdl_cx polygon2[ac2gdJ][2] = ac2gdl_cy polygon2[ac2gdJ][3] = 900 ac2gdJ = ac2gdJ + 1 polygon2[ac2gdJ][1] = 0 polygon2[ac2gdJ][2] = ac2gdl_lpa polygon2[ac2gdJ][3] = 4001 ac2gdJ = ac2gdJ + 1 endif if result = OUTPUT_TO_GDL_STACK then put ac2gdl_cx, ac2gdl_cy, 900, 0, ac2gdl_lpa, 4001 endif endif if ac2gdlI>1 & abs(ac2gdl_spx - ac2gdl_px) < EPS & abs(ac2gdl_spy - ac2gdl_py) < EPS then if result = OUTPUT_TO_PARAMETER then polygon2[ac2gdJ][1] = ac2gdl_px polygon2[ac2gdJ][2] = ac2gdl_py polygon2[ac2gdJ][3] = -1 ac2gdJ = ac2gdJ + 1 endif if result = OUTPUT_TO_GDL_STACK then put ac2gdl_px, ac2gdl_py, -1 endif else if result = OUTPUT_TO_PARAMETER then polygon2[ac2gdJ][1] = ac2gdl_px polygon2[ac2gdJ][2] = ac2gdl_py polygon2[ac2gdJ][3] = 1 ac2gdJ = ac2gdJ + 1 endif if result = OUTPUT_TO_GDL_STACK then put ac2gdl_px, ac2gdl_py, 1 endif endif ac2gdl_lpx = ac2gdl_px ac2gdl_lpy = ac2gdl_py ac2gdl_lpa = ac2gdl_pa next ac2gdlI return 200: ! ============================================================================== ! Point inside polygon check ! OPERATION_POINT_INSIDE_POLYGON ! ============================================================================== ! Input: ! srcPolygon1: input source of polygon 1 (INPUT_NO, INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK) ! polygon1: input polygon 1 ! srcPolygon2: input source of polygon 2 (INPUT_NO, INPUT_FROM_PARAMETER) ! polygon2: input polygon 2 ! srcPoint: input source of point (INPUT_NO, INPUT_FROM_PARAMETER) ! pntX: point X ! pntY: point Y ! result: output result (OUTPUT_TO_PARAMETER, OUTPUT_TO_GDL_STACK) ! GDL stack: coordX[1], coordY[1], arc[1], ... ! ! Output: ! ret: output status ! 0: Error ! 1: Inside ! 2: Outside ! 3: On Edge ! 4: On Point ! GDL stack: [1]: output status ! ============================================================================== ! Remarks: ! The polygon can be convex or concave too ! It works with polygons containing straight segments only ! The polygon can't contains holes ! The input polygon from polygon1 or from polygon2 must be closed ! The input polygon from GDL stack can be opened (it is closed automaticaly) ! ============================================================================== gosub 201 if result = OUTPUT_TO_GDL_STACK then put ret end endif end ret 201: pipNumPnts = 0 if srcPoint = INPUT_FROM_GDL_STACK then pntX = get(1) pntY = get(1) endif if srcPolygon1 = INPUT_FROM_GDL_STACK then dim pipPoly[][3] pipNumPnts = nsp/3 for pipI=1 to pipNumPnts pipPoly[pipI][1] = get(1) pipPoly[pipI][2] = get(1) pipPoly[pipI][3] = get(1) next pipI if abs(pipPoly[pipNumPnts][1] - pipPoly[1][1]) > EPS | abs(pipPoly[pipNumPnts][2] - pipPoly[1][2]) > EPS then pipNumPnts = pipNumPnts + 1 pipPoly[pipNumPnts][1] = pipPoly[1][1] ! Close polygon pipPoly[pipNumPnts][2] = pipPoly[1][2] endif endif if srcPolygon1 = INPUT_FROM_PARAMETER & srcPolygon2 = INPUT_NO then pipNumPnts = vardim1(polygon1) endif if srcPolygon1 = INPUT_NO & srcPolygon2 = INPUT_FROM_PARAMETER then pipNumPnts = vardim1(polygon2) endif if pipNumPnts = 0 then return ! Error ret = 0 ! Error pipEnd = 0 pipIntersection = 0 if srcPolygon1 = INPUT_FROM_GDL_STACK then pipX0 = pipPoly[pipNumPnts - 1][1] pipY0 = pipPoly[pipNumPnts - 1][2] pipX1 = pipPoly[1][1] pipY1 = pipPoly[1][2] endif if srcPolygon1 = INPUT_FROM_PARAMETER & srcPolygon2 = INPUT_NO then pipX0 = polygon1[pipNumPnts - 1][1] pipY0 = polygon1[pipNumPnts - 1][2] pipX1 = polygon1[1][1] pipY1 = polygon1[1][2] endif if srcPolygon1 = INPUT_NO & srcPolygon2 = INPUT_FROM_PARAMETER then pipX0 = polygon2[pipNumPnts - 1][1] pipY0 = polygon2[pipNumPnts - 1][2] pipX1 = polygon2[1][1] pipY1 = polygon2[1][2] endif for pipI=1 to pipNumPnts - 1 ! Point on polygon vertex test if abs(pipX1 - pntX) < EPS & abs(pipY1 - pntY) < EPS then ret = 4 ! OnPoint pipI = pipNumPnts - 1 ! Force end loop pipEnd = 1 endif ! Point on edge test pipSegLength = sqr((pipX0 - pipX1)^2 + (pipY0 - pipY1)^2) if pipSegLength > EPS & not(pipEnd) then if abs(abs((pipY0 - pipY1) * (pntX - pipX1) - (pipX0 - pipX1) * (pntY - pipY1)) / pipSegLength) < EPS then ret = 3 ! OnEdge pipEnd = 1 endif endif if srcPolygon1 = INPUT_FROM_GDL_STACK then pipX2 = pipPoly[pipI + 1][1] pipY2 = pipPoly[pipI + 1][2] endif if srcPolygon1 = INPUT_FROM_PARAMETER & srcPolygon2 = INPUT_NO then pipX2 = polygon1[pipI + 1][1] pipY2 = polygon1[pipI + 1][2] endif if srcPolygon1 = INPUT_NO & srcPolygon2 = INPUT_FROM_PARAMETER then pipX2 = polygon2[pipI + 1][1] pipY2 = polygon2[pipI + 1][2] endif srcLine1 = INPUT_FROM_PARAMETER line1X1 = pipX1 line1Y1 = pipY1 line1X2 = pipX2 line1Y2 = pipY2 srcLine2 = INPUT_FROM_PARAMETER line2X1 = pntX line2Y1 = pntY line2X2 = pntX + 1000 line2Y2 = pntY gosub 401 ! Segment-Segment intersection ! Result: state, cx,cy if state = 3 then if abs(line1X2 - cx) > EPS | abs(line1Y2 - cy) > EPS then if abs(line1X1 - cx) < EPS & abs(line1Y1 - cy) < EPS then if sgn(pipY0 - pntY) <> sgn(pipY2 - pntY) then pipIntersection = pipIntersection + 1 endif else pipIntersection = pipIntersection + 1 endif endif endif pipX0 = pipX1 pipY0 = pipY1 pipX1 = pipX2 pipY1 = pipY2 next pipI if pipEnd then return ! Already have valid result if (pipIntersection % 2 = 0) then ! Outside ret = 2 return else ! Inside ret = 1 return endif return 300: ! ============================================================================== ! Line - Line intersection ! ============================================================================== ! Input: ! srcLine1: input source of line 1 (INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK) ! line1X1: line1 startpoint X ! line1Y1: line1 startpoint Y ! line1X2: line1 endpoint X ! line1Y2: line1 endpoint Y ! srcLine2: input source of line 2 (INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK) ! line2X1: line2 startpoint X ! line2Y1: line2 startpoint Y ! line2X2: line2 endpoint X ! line2Y2: line2 endpoint Y ! result: output result (OUTPUT_TO_PARAMETER, OUTPUT_TO_GDL_STACK) ! GDL stack: line1X1, line1Y1, line1X2, line1Y2, ... ! ! Output: ! ret: output status ! 0: no intersection, parallel lines ! 1: lines are intersects ! cx: intersection point X ! cy: intersection point Y ! GDL stack: [1]: output status ! [2]: intersection point X ! [3]: intersection point Y ! ============================================================================== gosub 301 if result = OUTPUT_TO_GDL_STACK then put state, cx,cy end endif end state, cx,cy 301: if srcLine1 = INPUT_FROM_GDL_STACK then line1X1 = GET(1): line1Y1 = GET(1) ! S1 segment line1X2 = GET(1): line1Y2 = GET(1) endif if srcLine2 = INPUT_FROM_GDL_STACK then line2X1 = GET(1): line2Y1 = GET(1) ! S2 segment line2X2 = GET(1): line2Y2 = GET(1) endif lliDiv = (line1X1-line1X2) * (line2Y1-line2Y2) - (line1Y1-line1Y2) * (line2X1-line2X2) if abs(lliDiv) > EPS then ! Intersection temp1 = line1X1 * line1Y2 - line1Y1 * line1X2 temp2 = line2X1 * line2Y2 - line2Y1 * line2X2 tempx = temp1 * (line2X1-line2X2) - (line1X1-line1X2) * temp2 tempy = temp1 * (line2Y1-line2Y2) - (line1Y1-line1Y2) * temp2 state = 1 cx = (tempx / lliDiv) cy = (tempy / lliDiv) else ! No Intersection state = 0 cx = 0 cy = 0 endif return 400: ! ============================================================================== ! Segment - Segment intersection ! ============================================================================== ! Input: ! srcLine1: input source of line 1 (INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK) ! line1X1: line1 startpoint X ! line1Y1: line1 startpoint Y ! line1X2: line1 endpoint X ! line1Y2: line1 endpoint Y ! srcLine2: input source of line 2 (INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK) ! line2X1: line2 startpoint X ! line2Y1: line2 startpoint Y ! line2X2: line2 endpoint X ! line2Y2: line2 endpoint Y ! result: output result (OUTPUT_TO_PARAMETER, OUTPUT_TO_GDL_STACK) ! GDL stack: line1X1, line1Y1, line1X2, line1Y2, ... ! ! Output: ! ret: output status ! -1: no intersection, segments is not paralel ! 0: no intersection, parallel segments ! 1: intersection point lies on S1 segment, but not lies on S2 ! 2: intersection point lies on S2 segment, but not lies on S1 ! 3: intersection point lies on both segments ! cx: intersection point X ! cy: intersection point Y ! GDL stack: [1]: output status ! [2]: intersection point X ! [3]: intersection point Y ! ============================================================================== gosub 401 if result = OUTPUT_TO_GDL_STACK then put state, cx,cy end endif end state, cx,cy 401: if srcLine1 = INPUT_FROM_GDL_STACK then line1X1 = GET(1): line1Y1 = GET(1) ! S1 segment line1X2 = GET(1): line1Y2 = GET(1) srcLine1 = INPUT_FROM_PARAMETER endif if srcLine2 = INPUT_FROM_GDL_STACK then line2X1 = GET(1): line2Y1 = GET(1) ! S2 segment line2X2 = GET(1): line2Y2 = GET(1) srcLine2 = INPUT_FROM_PARAMETER endif gosub 301 ! Intersection of Line - Line if state then state = 0 if abs(line1X1 - line1X2) < EPS then if (line1Y1-EPS <= cy & cy <= line1Y2+EPS) | (line1Y1+EPS >= cy & cy >= line1Y2-EPS) then state = 1 else if (line1X1-EPS <= cx & cx <= line1X2+EPS) | (line1X1+EPS >= cx & cx >= line1X2-EPS) then state = 1 endif if abs(line2X1 - line2X2) < EPS then if (line2Y1-EPS <= cy & cy <= line2Y2+EPS) | (line2Y1+EPS >= cy & cy >= line2Y2-EPS) then state = state + 2 else if (line2X1-EPS <= cx & cx <= line2X2+EPS) | (line2X1+EPS >= cx & cx >= line2X2-EPS) then state = state + 2 endif if state = 0 then state = -1 endif return 500: ! ============================================================================== ! Intersect Polygons ! OPERATION_INTERSECT_POLYGONS ! ============================================================================== ! opmethod: contour staus handling method ! 0: edges with original status ! 1: set staus 0 (invisible) for all edges ! 2: set staus 1 (visible) for all edges ! 3: edges from polygon1 with 1, edges from polygon2 with 0 status ! 4: edges from polygon1 with 0, edges from polygon2 with 1 status ! 5: intersection point list ! srcPolygon1: input source of polygon 1 (INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK) ! polygon1: input polygon 1 ! srcPolygon2: input source of polygon 2 (INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK) ! polygon2: input polygon 2 ! result: output result (OUTPUT_TO_PARAMETER, OUTPUT_TO_GDL_STACK) ! ! Output: ! resPoly: output polygon ! GDL stack: coordX[1], coordY[1], status[1], ... ! ============================================================================== dim resPoly[][3] gosub 501 if result = OUTPUT_TO_GDL_STACK then for i=1 to vardim1(resPoly) put resPoly[1], resPoly[2], resPoly[3] next i end endif end resPoly 501: statusOriginal = (opmethod = 0) statusPolygon1 = (opmethod = 2 | opmethod = 3) * edgeAttribute statusPolygon2 = (opmethod = 2 | opmethod = 4) * edgeAttribute if srcPolygon1 = INPUT_FROM_PARAMETER then numPnts1 = vardim1(polygon1) endif if srcPolygon1 = INPUT_FROM_GDL_STACK then numPnts1 = nsp/3 for i=1 to numPnts1 polygon1[1] = get(1) polygon1[2] = get(1) polygon1[3] = get(1) next i endif if abs(polygon1[1][1] - polygon1[numPnts1][1]) > EPS | abs(polygon1[1][2] - polygon1[numPnts1][2]) > EPS then numPnts1 = numPnts1 + 1 polygon1[numPnts1][1] = polygon1[1][1] ! Close polygon1 polygon1[numPnts1][2] = polygon1[1][2] polygon1[numPnts1][3] = -1 endif if srcPolygon2 = INPUT_FROM_PARAMETER then numPnts2 = vardim1(polygon2) endif if srcPolygon2 = INPUT_FROM_GDL_STACK then numPnts2 = nsp/3 for i=1 to numPnts2 polygon2[1] = get(1) polygon2[2] = get(1) polygon2[3] = get(1) next i endif if abs(polygon2[1][1] - polygon2[numPnts2][1]) > EPS | abs(polygon2[1][2] - polygon2[numPnts2][2]) > EPS then numPnts2 = numPnts2 + 1 polygon2[numPnts2][1] = polygon2[1][1] ! Close polygon2 polygon2[numPnts2][2] = polygon2[1][2] polygon2[numPnts2][3] = -1 endif srcPoint = INPUT_FROM_PARAMETER srcPolygon1 = INPUT_NO srcPolygon2 = INPUT_FROM_PARAMETER pntX = polygon1[1][1] pntY = polygon1[1][2] gosub 201 ! Check inside ! Result: ret bInside = (ret = 1 | ret = 3) ! Inside or OnEdge srcPolygon1 = INPUT_FROM_PARAMETER srcPolygon2 = INPUT_NO gosub 601 ! Calculate area of polygon1 ! Result: area if area < 0 then gosub 701 ! Reverse polygon1 ! Result: polygon1 endif srcPolygon1 = INPUT_NO srcPolygon2 = INPUT_FROM_PARAMETER gosub 601 ! Calculate area of polygon2 ! Result: area if area < 0 then gosub 701 ! Reverse polygon2 ! Result: polygon2 endif ! Intersection poligons ======================================================== contour = not(bInside) bClosed = 0 id = 1 ci = 1 lastX = 0 safetyCounter = 0 safetyMax = numPnts1 + numPnts2 do if contour then if ci >= numPnts2 then ci = 1 srcPolygon1 = INPUT_FROM_PARAMETER srcPolygon2 = INPUT_NO pntX = polygon2[ci][1] pntY = polygon2[ci][2] pntS = polygon2[ci][3] else if ci >= numPnts1 then ci = 1 srcPolygon1 = INPUT_NO srcPolygon2 = INPUT_FROM_PARAMETER pntX = polygon1[ci][1] pntY = polygon1[ci][2] pntS = polygon1[ci][3] endif srcPoint = INPUT_FROM_PARAMETER gosub 201 ! Check inside ! Result: ret bInside = (ret = 1 | ret = 3) ! Inside or OnEdge if bInside then lastX = 0 if statusOriginal then status = pntS else if contour then status = statusPolygon1 else status = statusPolygon2 endif endif if opmethod <> 5 then resPoly[id][1] = pntX resPoly[id][2] = pntY resPoly[id][3] = status! pntS endif if id > 1 then if abs(resPoly[1][1] - pntX) < EPS & abs(resPoly[1][2] - pntY) < EPS then bClosed = 1 endif endif id = id + 1 endif ! Look for crossing sectinos line1X1 = pntX line1Y1 = pntY if contour then line1X2 = polygon2[ci + 1][1] line1Y2 = polygon2[ci + 1][2] else line1X2 = polygon1[ci + 1][1] line1Y2 = polygon1[ci + 1][2] endif bCrossIt = 0 bFinish = 0 j = 1 do if contour then line2X1 = polygon1[1] line2Y1 = polygon1 [2] line2X2 = polygon1[j + 1][1] line2Y2 = polygon1[j + 1][2] else line2X1 = polygon2 [1] line2Y1 = polygon2 [2] line2X2 = polygon2[j + 1][1] line2Y2 = polygon2[j + 1][2] endif srcLine1 = INPUT_FROM_PARAMETER srcLine2 = INPUT_FROM_PARAMETER gosub 401 ! Segment-Segment intersection ! Result: state, cx,cy if state = 3 then if (abs(line2X2 - cx) < EPS & abs(line2Y2 - cy) < EPS) then state = 0 endif if (abs(line1X1 - cx) < EPS & abs(line1Y1 - cy) < EPS) then state = 0 endif if id > 1 then for k=2 to id-1 if (abs(resPoly [1] - cx) < EPS & abs(resPoly [2] - cy) < EPS) then state = 0 bInside = not(bInside) endif next k endif endif if state = 3 then bCrossIt = 1 insertBefore = 0 if lastX then lenThis = (pntX - cx)^2 + (pntY - cy)^2 lenLast = (pntX - resPoly[id - 1][1])^2 + (pntY - resPoly[id - 1][2])^2 if lenLast > lenThis then insertBefore = 1 endif endif if statusOriginal then status = pntS else if contour then status = statusPolygon2 else status = statusPolygon1 endif endif if insertBefore then resPoly[id][1] = resPoly[id - 1][1] resPoly[id][2] = resPoly[id - 1][2] resPoly[id][3] = resPoly[id - 1][3] resPoly[id - 1][1] = cx resPoly[id - 1][2] = cy resPoly[id - 1][3] = status else resPoly[id][1] = cx resPoly[id][2] = cy resPoly[id][3] = status lastJ = j endif if id > 1 & not(insertBefore) then if abs(resPoly[1][1] - cx) < EPS & abs(resPoly[1][2] - cy) < EPS then bClosed = 1 endif endif id = id + 1 lancX = 0 if id > 2 then if (abs((cy - pntY) * (resPoly[id - 2][1] - pntX) - (cx - pntX) * (resPoly[id - 2][2] - line1Y1)) / SQR((cx - pntX)^2 + (cy - pntY)^2)) < EPS then lancX = 1 endif endif if not(lancX) then bCrossIt = 0 if bInside | lancX then if insertBefore then ci = lastJ - 1 else ci = j - 1 endif contour = not(contour) bFinish = 1 endif lastX = 1 endif j = j + 1 if contour then if j >= numPnts1 then bFinish = 1 else if j >= numPnts2 then bFinish = 1 endif while not(bCrossIt) & not(bFinish) ci = ci + 1 safetyCounter = safetyCounter + 1 if safetyCounter > safetyMax then bClosed = 1 while not(bClosed) resPoly[1][3] = resPoly[id-1][3] ! Set correct status of the first edge return 600: ! ============================================================================== ! Calculate polygon area ! ============================================================================== ! Input: ! srcPolygon1: input source of polygon 1 (INPUT_NO, INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK) ! polygon1: input polygon 1 ! srcPolygon2: input source of polygon 2 (INPUT_NO, INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK) ! polygon2: input polygon 2 ! result: output result (OUTPUT_TO_PARAMETER, OUTPUT_TO_GDL_STACK) ! GDL stack: coordX[1], coordY[1], arc[1], ... ! ! Output: ! area: area of polygon ! GDL stack: [1]: area of polygon ! ============================================================================== ! Remarks: ! The input polygon must have closed ! ============================================================================== gosub 601 if result = OUTPUT_TO_GDL_STACK then put area end endif end area 601: area = 0 if srcPolygon1 = INPUT_FROM_PARAMETER & srcPolygon2 = INPUT_NO then tempNumPnts = vardim1(polygon1) for areaI=1 to tempNumPnts-1 area = area + (polygon1[areaI+1][1] + polygon1[areaI][1]) * (polygon1[areaI+1][2] - polygon1[areaI][2]) * 0.5 next areaI area = area + (polygon1[1][1] + polygon1[tempNumPnts][1]) * (polygon1[1][2] - polygon1[tempNumPnts][2]) * 0.5 return endif if srcPolygon1 = INPUT_NO & srcPolygon2 = INPUT_FROM_PARAMETER then tempNumPnts = vardim1(polygon2) for areaI=1 to tempNumPnts-1 area = area + (polygon2[areaI+1][1] + polygon2[areaI][1]) * (polygon2[areaI+1][2] - polygon2[areaI][2]) * 0.5 next areaI area = area + (polygon2[1][1] + polygon2[tempNumPnts][1]) * (polygon2[1][2] - polygon2[tempNumPnts][2]) * 0.5 return endif if srcPolygon1 = INPUT_FROM_GDL_STACK | srcPolygon2 = INPUT_FROM_GDL_STACK then tempNumPnts = nsp/3 areaLX = get(1) ! Last point areaLY = get(1) areaFX = areaLX ! First point areaFY = areaLY for areaI=1 to tempNumPnts-1 areaX = get(1) areaY = get(1) area = area + (areaX + areaLX) * (areaY - areaLY) * 0.5 areaLX = areaX areaLY = areaY next areaI area = area + (areaFX + get(1)) * (areaFY - get(1)) * 0.5 return endif return 700: ! ============================================================================== ! Reverse polygon ! ============================================================================== ! Input: ! srcPolygon1: input source of polygon 1 (INPUT_NO, INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK) ! polygon1: input polygon 1 ! srcPolygon2: input source of polygon 2 (INPUT_NO, INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK) ! polygon2: input polygon 2 ! result: output result (OUTPUT_TO_PARAMETER, OUTPUT_TO_GDL_STACK) ! GDL stack: coordX[1], coordY[1], arc[1], ... ! ! Output: ! polygon1: output polygon1 ! polygon2: output polygon2 ! GDL stack: coordX[1], coordY[1], status[1], ... ! ============================================================================== dim tempPolygon[][3] gosub 701 if result = OUTPUT_TO_GDL_STACK then if srcPolygon1 = INPUT_FROM_PARAMETER & srcPolygon2 = INPUT_NO then for revI=1 to vardim1(polygon1) put polygon1[revI][1], polygon1[revI][2], polygon1[revI][3] next revI endif if srcPolygon1 = INPUT_NO & srcPolygon2 = INPUT_FROM_PARAMETER then for revI=1 to vardim1(polygon2) put polygon2[revI][1], polygon2[revI][2], polygon2[revI][3] next revI endif if srcPolygon1 = INPUT_FROM_GDL_STACK | srcPolygon2 = INPUT_FROM_GDL_STACK then for revI=1 to vardim1(tempPolygon) put tempPolygon[revI][1], tempPolygon[revI][2], tempPolygon[revI][3] next revI endif end endif if srcPolygon1 = INPUT_FROM_PARAMETER & srcPolygon2 = INPUT_NO then end polygon1 if srcPolygon1 = INPUT_NO & srcPolygon2 = INPUT_FROM_PARAMETER then end polygon2 if srcPolygon1 = INPUT_FROM_GDL_STACK | srcPolygon2 = INPUT_FROM_GDL_STACK then end tempPolygon 701: if srcPolygon1 = INPUT_FROM_PARAMETER & srcPolygon2 = INPUT_NO then tempNumPnts = vardim1(polygon1) for revI=1 to int(tempNumPnts / 2) tempX = polygon1[revI][1] tempY = polygon1[revI][2] tempS = polygon1[revI][3] polygon1[revI][1] = polygon1[tempNumPnts-revI+1][1] polygon1[revI][2] = polygon1[tempNumPnts-revI+1][2] polygon1[revI][3] = polygon1[tempNumPnts-revI+1][3] polygon1[tempNumPnts-revI+1][1] = tempX polygon1[tempNumPnts-revI+1][2] = tempY polygon1[tempNumPnts-revI+1][3] = tempS next revI return endif if srcPolygon1 = INPUT_NO & srcPolygon2 = INPUT_FROM_PARAMETER then tempNumPnts = vardim1(polygon2) for revI=1 to int(tempNumPnts / 2) tempX = polygon2[revI][1] tempY = polygon2[revI][2] tempS = polygon2[revI][3] polygon2[revI][1] = polygon2[tempNumPnts-revI+1][1] polygon2[revI][2] = polygon2[tempNumPnts-revI+1][2] polygon2[revI][3] = polygon2[tempNumPnts-revI+1][3] polygon2[tempNumPnts-revI+1][1] = tempX polygon2[tempNumPnts-revI+1][2] = tempY polygon2[tempNumPnts-revI+1][3] = tempS next revI return endif if srcPolygon1 = INPUT_FROM_GDL_STACK | srcPolygon2 = INPUT_FROM_GDL_STACK then tempNumPnts = nsp/3 for revI=1 to tempNumPnts tempPolygon[revI][1] = get(1) tempPolygon[revI][2] = get(1) tempPolygon[revI][3] = get(1) next revI for revI=1 to int(tempNumPnts / 2) tempX = tempPolygon[revI][1] tempY = tempPolygon[revI][2] tempS = tempPolygon[revI][3] tempPolygon[revI][1] = tempPolygon[tempNumPnts-revI+1][1] tempPolygon[revI][2] = tempPolygon[tempNumPnts-revI+1][2] tempPolygon[revI][3] = tempPolygon[tempNumPnts-revI+1][3] tempPolygon[tempNumPnts-revI+1][1] = tempX tempPolygon[tempNumPnts-revI+1][2] = tempY tempPolygon[tempNumPnts-revI+1][3] = tempS next revI endif return
ā2013-02-05 11:36 AM
ā2013-02-05 04:47 PM
