intersection point of two lines
Hmooslechner
i try to get the intersection point of two lines:
line2 x11, y11, x12, x12
line2 x21, y21, x22, y22
is there a simple solution for this?
I am not so settlet in vector mathematics.. and tried it over the angles but my brain now is boiling...
I hope someone can help - thanks forwarding..
14 REPLIES 14
Hmooslechner
Meanwhile i found this:
http://www.graphisoft.com/ftp/techsupport/documentation/developer_docs/BasicLibraryDoc/16/Window-Mac...
But my Archicad cant find the Macro - how can i test if archicad has loaded the apx?
And does anybody know a direct GDL-Anser to this? Without the polygon opreation macro?
Pertti Paasky
Hi ,Hmooslechner
You can find formulas and other staff for example here
http://paulbourke.net/geometry/pointlineplane/
- be cool -
- AC-24 FIN - WIN 10 - HP Zbook -
“A winner is just a loser who tried one more time.”
George M. Moore, Jr.
Hello,
Here is a line-line intersection object, which is using
built-in polygon operations macros.
Here is a preview, hope the object works.
Frank Beister
After a standard installation of AC 16 (GER) the basic library seems not to be part of the national library. At least the PolyOperations makro is not available for custom designed objects.
AFAIR with update to ArchiCAD 14 this has changed. I have asked for this in the past, but haven't got any answer.
Can anyone confirm this general lack or are the basic library macros available in other localised versions? Can others download and use Juhas example object in ArchiCAD 16?
Donnerwetter!
It is working in ArchiCAD 16 FIN.
Here is the polygon operations macro in version 16 if someone needs it.
Hope GS does not sue me for distributing warez here
...and here is the code (master script) if you want to make a macro of your own.
EPS = 0.0001
OPERATION_CONVERT_POLYGON_AC_TO_GDL		= 1
OPERATION_POINT_INSIDE_POLYGON			= 2
OPERATION_LINE_LINE_INTERSECTION		= 3
OPERATION_SEGMENT_SEGMENT_INTERSECTION	= 4
OPERATION_INTERSECT_POLYGONS			= 5
OPERATION_CALCULATE_POLYGON_AREA		= 6
OPERATION_REVERSE_POLYGON				= 7
INPUT_NO			 = 0
INPUT_FROM_PARAMETER = 1
INPUT_FROM_GDL_STACK = 2
OUTPUT_TO_PARAMETER = 1
OUTPUT_TO_GDL_STACK = 2
bCalledFromScript = 0
if opcode = OPERATION_CONVERT_POLYGON_AC_TO_GDL		then 100	! Convert polygon: AC polygon -> GDL polygon
if opcode = OPERATION_POINT_INSIDE_POLYGON			then 200	! Point inside polygon check
if opcode = OPERATION_LINE_LINE_INTERSECTION		then 300	! Line-Line intersection
if opcode = OPERATION_SEGMENT_SEGMENT_INTERSECTION	then 400	! Segment-Segment intersection
if opcode = OPERATION_INTERSECT_POLYGONS			then 500	! Intersect polygons
if opcode = OPERATION_CALCULATE_POLYGON_AREA		then 600	! Calculate polygon area
if opcode = OPERATION_REVERSE_POLYGON				then 700	! Reverse polygon
end
100:
!	OPERATION_CONVERT_POLYGON_AC_TO_GDL
! Input:
!	srcPolygon1:	input source of polygon 1 (INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK)
!	polygon1:		input polygon
!	result:			output result (OUTPUT_TO_PARAMETER, OUTPUT_TO_GDL_STACK)
!	GDL stack:		coordX[1], coordY[1], arc[1], ...
! Output:
!	polygon2:		output polygon
!	GDL stack:		coordX[1], coordY[1], status[1], ...
gosub 101
if result = OUTPUT_TO_GDL_STACK then end
end polygon2
101:
	if srcPolygon1 = INPUT_FROM_PARAMETER then
		numPnts = vardim1(polygon1)
	endif
	if srcPolygon1 = INPUT_FROM_GDL_STACK then
		numPnts = nsp/3
	endif
	ac2gdl_lpa = 0
	ac2gdJ = 1
	for ac2gdlI = 1 to numPnts
			ac2gdl_px = polygon1[ac2gdlI][1]
			ac2gdl_py = polygon1[ac2gdlI][2]
			ac2gdl_pa = polygon1[ac2gdlI][3]
		endif
			ac2gdl_px = get(1)
			ac2gdl_py = get(1)
			ac2gdl_pa = get(1)
		endif
		if ac2gdlI = 1 then
			ac2gdl_spx = ac2gdl_px
			ac2gdl_spy = ac2gdl_py
		endif
		if abs(ac2gdl_lpa) > EPS then
			ac2gdl_mx = (ac2gdl_px + ac2gdl_lpx) / 2
			ac2gdl_my = (ac2gdl_py + ac2gdl_lpy) / 2
			ac2gdl_ratio = 1 / 2 / tan (ac2gdl_lpa / 2)
			ac2gdl_cx = ac2gdl_mx - ac2gdl_ratio * (ac2gdl_py - ac2gdl_lpy)	! Arc center
			ac2gdl_cy = ac2gdl_my + ac2gdl_ratio * (ac2gdl_px - ac2gdl_lpx)
			if result = OUTPUT_TO_PARAMETER then
				polygon2[ac2gdJ][1] = ac2gdl_cx
				polygon2[ac2gdJ][2] = ac2gdl_cy
				polygon2[ac2gdJ][3] = 900
				ac2gdJ = ac2gdJ + 1
				polygon2[ac2gdJ][1] = 0
				polygon2[ac2gdJ][2] = ac2gdl_lpa
				polygon2[ac2gdJ][3] = 4001
				ac2gdJ = ac2gdJ + 1
			endif
				put ac2gdl_cx,	ac2gdl_cy,	900,
					0,			ac2gdl_lpa,	4001
			endif
		endif
		if ac2gdlI>1 & abs(ac2gdl_spx - ac2gdl_px) < EPS & abs(ac2gdl_spy - ac2gdl_py) < EPS then
				polygon2[ac2gdJ][1] = ac2gdl_px
				polygon2[ac2gdJ][2] = ac2gdl_py
				polygon2[ac2gdJ][3] = -1
				ac2gdJ = ac2gdJ + 1
			endif
				put ac2gdl_px, ac2gdl_py, -1
			endif
		else
				polygon2[ac2gdJ][3] = 1
				ac2gdJ = ac2gdJ + 1
			endif
				put ac2gdl_px, ac2gdl_py, 1
			endif
		endif
		ac2gdl_lpx = ac2gdl_px
		ac2gdl_lpy = ac2gdl_py
		ac2gdl_lpa = ac2gdl_pa
	next ac2gdlI
return
200:
!	OPERATION_POINT_INSIDE_POLYGON
! Input:
!	srcPolygon1:	input source of polygon 1 (INPUT_NO, INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK)
!	polygon1:		input polygon 1
!	srcPolygon2:	input source of polygon 2 (INPUT_NO, INPUT_FROM_PARAMETER)
!	polygon2:		input polygon 2
!	srcPoint:		input source of point (INPUT_NO, INPUT_FROM_PARAMETER)
!	pntX:			point X
!	pntY:			point Y
! Output:
!	ret:			output status
!						0: Error
!						1: Inside
!						2: Outside
!						3: On Edge
!						4: On Point
!	GDL stack:		[1]: output status
! Remarks:
!	The polygon can be convex or concave too
!	It works with polygons containing straight segments only
!	The polygon can't contains holes
!	The input polygon from polygon1 or from polygon2 must be closed
!	The input polygon from GDL stack can be opened (it is closed automaticaly)
gosub 201
	put ret
	end
endif
end ret
201:
	pipNumPnts = 0
	if srcPoint = INPUT_FROM_GDL_STACK then
		pntX = get(1)
		pntY = get(1)
	endif
		dim pipPoly[][3]
		pipNumPnts = nsp/3
		for pipI=1 to pipNumPnts
			pipPoly[pipI][1] = get(1)
			pipPoly[pipI][2] = get(1)
			pipPoly[pipI][3] = get(1)
		next pipI
		if abs(pipPoly[pipNumPnts][1] - pipPoly[1][1]) > EPS | abs(pipPoly[pipNumPnts][2] - pipPoly[1][2]) > EPS then
			pipNumPnts = pipNumPnts + 1
			pipPoly[pipNumPnts][1] = pipPoly[1][1]	! Close polygon
			pipPoly[pipNumPnts][2] = pipPoly[1][2]
		endif
	endif
	if srcPolygon1 = INPUT_FROM_PARAMETER & srcPolygon2 = INPUT_NO then
		pipNumPnts = vardim1(polygon1)
	endif
	if srcPolygon1 = INPUT_NO & srcPolygon2 = INPUT_FROM_PARAMETER then
		pipNumPnts = vardim1(polygon2)
	endif
	if pipNumPnts = 0 then return	! Error
	ret = 0		! Error
	pipEnd = 0
	pipIntersection = 0
		pipX0 = pipPoly[pipNumPnts - 1][1]
		pipY0 = pipPoly[pipNumPnts - 1][2]
		pipX1 = pipPoly[1][1]
		pipY1 = pipPoly[1][2]
	endif
		pipX0 = polygon1[pipNumPnts - 1][1]
		pipY0 = polygon1[pipNumPnts - 1][2]
		pipX1 = polygon1[1][1]
		pipY1 = polygon1[1][2]
	endif
		pipX0 = polygon2[pipNumPnts - 1][1]
		pipY0 = polygon2[pipNumPnts - 1][2]
		pipX1 = polygon2[1][1]
		pipY1 = polygon2[1][2]
	endif
	for pipI=1 to pipNumPnts - 1
		! Point on polygon vertex test
		if abs(pipX1 - pntX) < EPS & abs(pipY1 - pntY) < EPS then
			ret		= 4					! OnPoint
			pipI	= pipNumPnts - 1	! Force end loop
			pipEnd	= 1
		endif
		! Point on edge test
		pipSegLength = sqr((pipX0 - pipX1)^2 + (pipY0 - pipY1)^2)
		if pipSegLength > EPS & not(pipEnd) then
			if abs(abs((pipY0 - pipY1) * (pntX - pipX1) - (pipX0 - pipX1) * (pntY - pipY1)) / pipSegLength) < EPS then
				ret		= 3					! OnEdge
				pipEnd	= 1
			endif
		endif
			pipX2 = pipPoly[pipI + 1][1]
			pipY2 = pipPoly[pipI + 1][2]
		endif
			pipX2 = polygon1[pipI + 1][1]
			pipY2 = polygon1[pipI + 1][2]
		endif
			pipX2 = polygon2[pipI + 1][1]
			pipY2 = polygon2[pipI + 1][2]
		endif
		srcLine1 = INPUT_FROM_PARAMETER
		line1X1 = pipX1
		line1Y1 = pipY1
		line1X2 = pipX2
		line1Y2 = pipY2
		srcLine2 = INPUT_FROM_PARAMETER
		line2X1 = pntX
		line2Y1 = pntY
		line2X2 = pntX + 1000
		line2Y2 = pntY
		gosub 401	! Segment-Segment intersection
					! Result: state, cx,cy
		if state = 3 then
			if abs(line1X2 - cx) > EPS | abs(line1Y2 - cy) > EPS then
				if abs(line1X1 - cx) < EPS & abs(line1Y1 - cy) < EPS then
					if sgn(pipY0 - pntY) <> sgn(pipY2 - pntY) then
						pipIntersection = pipIntersection + 1
					endif
				else
				endif
			endif
		endif
		pipX0 = pipX1
		pipY0 = pipY1
		pipX1 = pipX2
		pipY1 = pipY2
	next pipI
	if pipEnd then return	! Already have valid result
	if (pipIntersection % 2 = 0) then	! Outside
		ret = 2
		return
	else	! Inside
		ret = 1
		return
	endif
return
300:
! Line - Line intersection
! Input:
!	srcLine1:		input source of line 1 (INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK)
!	line1X1:		line1 startpoint X
!	line1Y1:		line1 startpoint Y
!	line1X2:		line1 endpoint X
!	line1Y2:		line1 endpoint Y
!	srcLine2:		input source of line 2 (INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK)
!	line2X1:		line2 startpoint X
!	line2Y1:		line2 startpoint Y
!	line2X2:		line2 endpoint X
!	line2Y2:		line2 endpoint Y
!	GDL stack:		line1X1, line1Y1, line1X2, line1Y2, ...
! Output:
!						 0: no intersection, parallel lines
!						 1: lines are intersects
!	cx:				intersection point X
!	cy:				intersection point Y
!					[2]: intersection point X
!					[3]: intersection point Y
gosub 301
	put state, cx,cy
	end
endif
end state, cx,cy
301:
	if srcLine1 = INPUT_FROM_GDL_STACK then
		line1X1 = GET(1): line1Y1 = GET(1)	! S1 segment
		line1X2 = GET(1): line1Y2 = GET(1)
	endif
	if srcLine2 = INPUT_FROM_GDL_STACK then
		line2X1 = GET(1): line2Y1 = GET(1)	! S2 segment
		line2X2 = GET(1): line2Y2 = GET(1)
	endif
	lliDiv = (line1X1-line1X2) * (line2Y1-line2Y2) - (line1Y1-line1Y2) * (line2X1-line2X2)
	if abs(lliDiv) > EPS then
		! Intersection
		temp1 = line1X1 * line1Y2 - line1Y1 * line1X2
		temp2 = line2X1 * line2Y2 - line2Y1 * line2X2
		tempx = temp1 * (line2X1-line2X2) - (line1X1-line1X2) * temp2
		tempy = temp1 * (line2Y1-line2Y2) - (line1Y1-line1Y2) * temp2
		state = 1
		cx = (tempx / lliDiv)
		cy = (tempy / lliDiv)
	else
		! No Intersection
		state = 0
		cx = 0
		cy = 0
	endif
return
400:
! Segment - Segment intersection
! Input:
! Output:
!						-1: no intersection, segments is not paralel
!						 0: no intersection, parallel segments
!						 1: intersection point lies on S1 segment, but not lies on S2
!						 2: intersection point lies on S2 segment, but not lies on S1
!						 3: intersection point lies on both segments
gosub 401
	put state, cx,cy
	end
endif
end state, cx,cy
401:
	endif
	endif
	gosub 301	! Intersection of Line - Line
	if state then
		state = 0
		if abs(line1X1 - line1X2) < EPS then
			if (line1Y1-EPS <= cy & cy <= line1Y2+EPS) | (line1Y1+EPS >= cy & cy >= line1Y2-EPS) then state = 1
		else
			if (line1X1-EPS <= cx & cx <= line1X2+EPS) | (line1X1+EPS >= cx & cx >= line1X2-EPS) then state = 1
		endif
		if abs(line2X1 - line2X2) < EPS then
			if (line2Y1-EPS <= cy & cy <= line2Y2+EPS) | (line2Y1+EPS >= cy & cy >= line2Y2-EPS) then state = state + 2
		else
			if (line2X1-EPS <= cx & cx <= line2X2+EPS) | (line2X1+EPS >= cx & cx >= line2X2-EPS) then state = state + 2
		endif
		if state = 0 then state = -1
	endif
return
500:
! Intersect Polygons
!	OPERATION_INTERSECT_POLYGONS
!	opmethod:		contour staus handling method
!						0: edges with original status
!						1: set staus 0 (invisible) for all edges
!						2: set staus 1 (visible) for all edges
!						3: edges from polygon1 with 1, edges from polygon2 with 0 status
!						4: edges from polygon1 with 0, edges from polygon2 with 1 status
!						5: intersection point list
!	srcPolygon2:	input source of polygon 2 (INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK)
! Output:
!	resPoly:		output polygon
dim resPoly[][3]
gosub 501
	for i=1 to vardim1(resPoly)
		put resPoly[1],
			resPoly[2],
			resPoly[3]
	next i
	end
endif
end resPoly
501:
	statusOriginal = (opmethod = 0)
	statusPolygon1 = (opmethod = 2 | opmethod = 3) * edgeAttribute
	statusPolygon2 = (opmethod = 2 | opmethod = 4) * edgeAttribute
		numPnts1 = vardim1(polygon1)
	endif
		numPnts1 = nsp/3
		for i=1 to numPnts1
			polygon1[1] = get(1)
			polygon1[2] = get(1)
			polygon1[3] = get(1)
		next i
	endif
	if abs(polygon1[1][1] - polygon1[numPnts1][1]) > EPS | abs(polygon1[1][2] - polygon1[numPnts1][2]) > EPS then
		numPnts1 = numPnts1 + 1
		polygon1[numPnts1][1] = polygon1[1][1]	! Close polygon1
		polygon1[numPnts1][2] = polygon1[1][2]
		polygon1[numPnts1][3] = -1
	endif
	if srcPolygon2 = INPUT_FROM_PARAMETER then
		numPnts2 = vardim1(polygon2)
	endif
	if srcPolygon2 = INPUT_FROM_GDL_STACK then
		numPnts2 = nsp/3
		for i=1 to numPnts2
			polygon2[1] = get(1)
			polygon2[2] = get(1)
			polygon2[3] = get(1)
		next i
	endif
	if abs(polygon2[1][1] - polygon2[numPnts2][1]) > EPS | abs(polygon2[1][2] - polygon2[numPnts2][2]) > EPS then
		numPnts2 = numPnts2 + 1
		polygon2[numPnts2][1] = polygon2[1][1]	! Close polygon2
		polygon2[numPnts2][2] = polygon2[1][2]
		polygon2[numPnts2][3] = -1
	endif
	srcPoint	= INPUT_FROM_PARAMETER
	pntX = polygon1[1][1]
	pntY = polygon1[1][2]
	gosub 201		! Check inside
					! Result: ret
	bInside = (ret = 1 | ret = 3)	! Inside or OnEdge
	gosub 601		! Calculate area of polygon1
					! Result: area
	if area < 0 then
		gosub 701		! Reverse polygon1
						! Result: polygon1
	endif
	gosub 601		! Calculate area of polygon2
					! Result: area
	if area < 0 then
		gosub 701		! Reverse polygon2
						! Result: polygon2
	endif
! Intersection poligons ========================================================
	contour = not(bInside)
	bClosed = 0
	id = 1
	ci = 1
	lastX = 0
	safetyCounter = 0
	safetyMax = numPnts1 + numPnts2
	do
		if contour then
			if ci >= numPnts2 then ci = 1
			pntX = polygon2[ci][1]
			pntY = polygon2[ci][2]
			pntS = polygon2[ci][3]
		else
			if ci >= numPnts1 then ci = 1
			pntX = polygon1[ci][1]
			pntY = polygon1[ci][2]
			pntS = polygon1[ci][3]
		endif
						! Result: ret
		if bInside then
			lastX = 0
			if statusOriginal then
				status = pntS
			else
				if contour then
					status = statusPolygon1
				else
					status = statusPolygon2
				endif
			endif
			if opmethod <> 5 then
				resPoly[id][1] = pntX
				resPoly[id][2] = pntY
				resPoly[id][3] = status!		pntS
			endif
			if id > 1 then
				if abs(resPoly[1][1] - pntX) < EPS & abs(resPoly[1][2] - pntY) < EPS then
					bClosed = 1
				endif
			endif
			id = id + 1
		endif
		! Look for crossing sectinos
		line1X1 = pntX
		line1Y1 = pntY
		if contour then
			line1X2 = polygon2[ci + 1][1]
			line1Y2 = polygon2[ci + 1][2]
		else
			line1X2 = polygon1[ci + 1][1]
			line1Y2 = polygon1[ci + 1][2]
		endif
		bCrossIt = 0
		bFinish = 0
		j = 1
		do
			if contour then
				line2X1 = polygon1[1]
				line2Y1 = polygon1[2]
				line2X2 = polygon1[j + 1][1]
				line2Y2 = polygon1[j + 1][2]
			else
				line2X1 = polygon2[1]
				line2Y1 = polygon2[2]
				line2X2 = polygon2[j + 1][1]
				line2Y2 = polygon2[j + 1][2]
			endif
			if state = 3 then
				if (abs(line2X2 - cx) < EPS & abs(line2Y2 - cy) < EPS) then
					state = 0
				endif
				if (abs(line1X1 - cx) < EPS & abs(line1Y1 - cy) < EPS) then
					state = 0
				endif
				if id > 1 then
					for k=2 to id-1
						if (abs(resPoly[1] - cx) < EPS & abs(resPoly[2] - cy) < EPS) then
							state = 0
							bInside = not(bInside)
						endif
					next k
				endif
			endif
			if state = 3 then
				bCrossIt = 1
				insertBefore = 0
				if lastX then
					lenThis = (pntX - cx)^2 + (pntY - cy)^2
					lenLast = (pntX - resPoly[id - 1][1])^2 + (pntY - resPoly[id - 1][2])^2
					if lenLast > lenThis then
						insertBefore = 1
					endif
				endif
					status = pntS
				else
					if contour then
					else
					endif
				endif
				if insertBefore then
					resPoly[id][1] = resPoly[id - 1][1]
					resPoly[id][2] = resPoly[id - 1][2]
					resPoly[id][3] = resPoly[id - 1][3]
					resPoly[id - 1][1] = cx
					resPoly[id - 1][2] = cy
					resPoly[id - 1][3] = status
				else
					resPoly[id][1] = cx
					resPoly[id][2] = cy
					lastJ = j
				endif
				if id > 1 & not(insertBefore) then
					if abs(resPoly[1][1] - cx) < EPS & abs(resPoly[1][2] - cy) < EPS then
						bClosed = 1
					endif
				endif
				id = id + 1
				lancX = 0
				if id > 2 then
					if (abs((cy - pntY) * (resPoly[id - 2][1] - pntX) - (cx - pntX) * (resPoly[id - 2][2] - line1Y1)) / SQR((cx - pntX)^2 + (cy - pntY)^2)) < EPS then
						lancX = 1
					endif
				endif
				if not(lancX) then bCrossIt = 0
				if bInside | lancX then
						ci = lastJ - 1
					else
						ci = j - 1
					endif
					contour = not(contour)
					bFinish = 1
				endif
				lastX = 1
			endif
			j = j + 1
			if contour then
				if j >= numPnts1 then bFinish = 1
			else
				if j >= numPnts2 then bFinish = 1
			endif
		while not(bCrossIt) & not(bFinish)
		ci = ci + 1
		safetyCounter = safetyCounter + 1
		if safetyCounter > safetyMax then bClosed = 1
	while not(bClosed)
	resPoly[1][3] = resPoly[id-1][3]	! Set correct status of the first edge
return
600:
! Input:
!	srcPolygon2:	input source of polygon 2 (INPUT_NO, INPUT_FROM_PARAMETER, INPUT_FROM_GDL_STACK)
! Output:
!	area:			area of polygon
!	GDL stack:		[1]: area of polygon
! Remarks:
!	The input polygon must have closed
gosub 601
	put area
	end
endif
end area
601:
	area = 0
		tempNumPnts = vardim1(polygon1)
		for areaI=1 to tempNumPnts-1
			area = area + (polygon1[areaI+1][1] + polygon1[areaI][1]) * (polygon1[areaI+1][2] - polygon1[areaI][2]) * 0.5
		next areaI
		area = area + (polygon1[1][1] + polygon1[tempNumPnts][1]) * (polygon1[1][2] - polygon1[tempNumPnts][2]) * 0.5
		return
	endif
		tempNumPnts = vardim1(polygon2)
			area = area + (polygon2[areaI+1][1] + polygon2[areaI][1]) * (polygon2[areaI+1][2] - polygon2[areaI][2]) * 0.5
		next areaI
		area = area + (polygon2[1][1] + polygon2[tempNumPnts][1]) * (polygon2[1][2] - polygon2[tempNumPnts][2]) * 0.5
		return
	endif
	if srcPolygon1 = INPUT_FROM_GDL_STACK | srcPolygon2 = INPUT_FROM_GDL_STACK then
		tempNumPnts = nsp/3
		areaLX = get(1)	! Last point
		areaLY = get(1)
		areaFX = areaLX	! First point
		areaFY = areaLY
			areaX = get(1)
			areaY = get(1)
			area = area + (areaX + areaLX) * (areaY - areaLY) * 0.5
			areaLX = areaX
			areaLY = areaY
		next areaI
		area = area + (areaFX + get(1)) * (areaFY - get(1)) * 0.5
		return
	endif
return
700:
! Reverse polygon
! Input:
! Output:
!	polygon1:		output polygon1
!	polygon2:		output polygon2
dim tempPolygon[][3]
gosub 701
		for revI=1 to vardim1(polygon1)
			put polygon1[revI][1],
				polygon1[revI][2],
				polygon1[revI][3]
		next revI
	endif
		for revI=1 to vardim1(polygon2)
			put polygon2[revI][1],
				polygon2[revI][2],
				polygon2[revI][3]
		next revI
	endif
		for revI=1 to vardim1(tempPolygon)
			put tempPolygon[revI][1],
				tempPolygon[revI][2],
				tempPolygon[revI][3]
		next revI
	endif
	end
endif
if srcPolygon1 = INPUT_FROM_PARAMETER & srcPolygon2 = INPUT_NO then end polygon1
if srcPolygon1 = INPUT_NO & srcPolygon2 = INPUT_FROM_PARAMETER then end polygon2
if srcPolygon1 = INPUT_FROM_GDL_STACK | srcPolygon2 = INPUT_FROM_GDL_STACK then end tempPolygon
701:
		for revI=1 to int(tempNumPnts / 2)
			tempX = polygon1[revI][1]
			tempY = polygon1[revI][2]
			tempS = polygon1[revI][3]
			polygon1[revI][1] = polygon1[tempNumPnts-revI+1][1]
			polygon1[revI][2] = polygon1[tempNumPnts-revI+1][2]
			polygon1[revI][3] = polygon1[tempNumPnts-revI+1][3]
			polygon1[tempNumPnts-revI+1][1] = tempX
			polygon1[tempNumPnts-revI+1][2] = tempY
			polygon1[tempNumPnts-revI+1][3] = tempS
		next revI
		return
	endif
			tempX = polygon2[revI][1]
			tempY = polygon2[revI][2]
			tempS = polygon2[revI][3]
			polygon2[revI][1] = polygon2[tempNumPnts-revI+1][1]
			polygon2[revI][2] = polygon2[tempNumPnts-revI+1][2]
			polygon2[revI][3] = polygon2[tempNumPnts-revI+1][3]
			polygon2[tempNumPnts-revI+1][1] = tempX
			polygon2[tempNumPnts-revI+1][2] = tempY
			polygon2[tempNumPnts-revI+1][3] = tempS
		next revI
		return
	endif
		tempNumPnts = nsp/3
		for revI=1 to tempNumPnts
			tempPolygon[revI][1] = get(1)
			tempPolygon[revI][2] = get(1)
			tempPolygon[revI][3] = get(1)
		next revI
			tempX = tempPolygon[revI][1]
			tempY = tempPolygon[revI][2]
			tempS = tempPolygon[revI][3]
			tempPolygon[revI][1] = tempPolygon[tempNumPnts-revI+1][1]
			tempPolygon[revI][2] = tempPolygon[tempNumPnts-revI+1][2]
			tempPolygon[revI][3] = tempPolygon[tempNumPnts-revI+1][3]
			tempPolygon[tempNumPnts-revI+1][1] = tempX
			tempPolygon[tempNumPnts-revI+1][2] = tempY
			tempPolygon[tempNumPnts-revI+1][3] = tempS
		next revI
	endif
return
undefined
Frank Beister
Thanks. I have the recent versions and have downloaded library development kit, which comes with the library.
Hmooslechner
Next week i have a lot of scripting-Work with this! Many thanks so far!
