.lcf files
Is there an advantage to putting all your frequently used library parts into a container as opposed to just in a folder? Does it load parts faster or save disk space or anything like that?
Thanks,
Rick
14 REPLIES 14
cremsberg
So how does one open an .lcf container library and then make a new .lcf file container?
Claire Remsberg
Remsberg Architecture, P.A.
MacBook Pro, OSX 12.6, ArchiCAD v25 (5010)
__archiben
File>Libraries and Objects>Create/Extract a Container...
~/archiben
b e n f r o s t
David Maudlin
Theses commands might have to be added to your Work Environment.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
__archiben
david - these are in the 'Standard' profile installed and operational by default . . .
~/archiben
b e n f r o s t
David Maudlin
Ben:
You are correct, and they are in the "Layouting" and "Visualization" WEs as well. Guess I must have been thinking back to when these commands were added and did not show in older imported WEs.
David
