library report
hello everyone !
is there a way to see from which of the loaded libraries one project is using objects so that you can remove some of the libraries that are loaded but are not in use?
i hope its clear what im trying to say
3 Replies 3
David Larrew
You can "Save As" the project file as an archive (.PLA). then "Open" the .PLA and choose the option "Extract elements to a folder". This will create a .LIB folder with all objects that were inserted in the original file. You can then manually compare the .LIB sub-folders to the loaded libraries.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Stuart Atkinson
You could use the library manager.
Remove one library, hit reload, if any objects are now missing you will get a list of "missing objects" in your library loading report.
If missing objects then add it back in.
Do this for all libraries.
Cheers
Stuart
many thanks 🙂
