loding model
please help me out with loding model. I load model from the internet, unzip them and load into the liberary manager, but after I open object setting, I still cannot find those model. Please teach me how to load those model success into the ArchiCAD. Thank you!
8 REPLIES 8
Djordje
You mean library parts?
You should organize your downloaded ArchiCAD library parts in a folder. Then load that folder in Library manager as a part of the current library. Then you should be able to use them in your projects.
Are the objects that you downloaded ArchiCAD library parts or some other 3D format?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I downlard those model from http://www.hermanmiller.com/. It's DWG file. I try to open those file from the library manager, but it doesn't work. then my ex-teacher told me that I need to use GDL to change DWG file to DWG. But I still have proble to change file. Can you teach me how to do that step by step? :oops:
Djordje
http://www.graphisoft.com/archiguide_archive/ArchiGuide_Online_6o/issue20/3ddxfimport.html
Djordje
HP Omen
Djordje,
Thank you for your help. You don't know how much you just help me out :lol:
Djordje
ashley wrote:
Djordje,
I might guess 😉
Ayway - go through the ArchiGuide, lots of How To articles are there.
Good luck!
Djordje
HP Omen
thanks again
tsturm
Djordje
The link you provide leaves you hanging in the process..
It states at the very end
Do try this at home, but be patient! If you are even more patient, read on to learn how to tweak the imported model!
Yet there is no additional link to continue on.
Ashley might find this information helpful.
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
Djordje
The next topic describes how to tweak the imported models. I wrote both back in 6.5 times, and it was not updated since - not that it does not need updating ...
Djordje
HP Omen
