looking for special door
Anybody have or know where possible get roller shutter door object?
7 REPLIES 7
Gerald Hoffman
Sigitas,
You should add a signature to your profile as it can help people to answer you more accurately. The only one I have found is in Cadimage D&W Builder. It is located in the Garage Door builder object. I use the add-on all the time and think it is worth the cost in time alone spent looking for ways to get certain doors and windows.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
Thanks, a lot of
Djordje
I normally use garage doors and enlarge them appropriately. Works.
Offset the door for the thickness of the wall.
If you want to show the door rails, then there were German garage doors that had those too.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
vistasp
Can we download this German library from somewhere Djordje? I can't find the link to Bibliotheken 11 or 12.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Djordje
Of course you can't 😉
http://www.gshelp.de/CDownloads/AC12/Downloads12Bibliotheken.html
And it also comes with the Testversion ...
Djordje
HP Omen
vistasp
Thanks Djordje. In that case, I'll try not to.
= v i s t a s p =
bT Square Peg
Or....... you can search archicadwiki for torrent downloads
http://www.archicadwiki.com/ArchiCAD%20Bittorrent%20Downloads
