2007-04-10 02:49 PM
2007-04-12 04:33 PM
jeppe.liisberg wrote:It's hard to respond without knowing precisely what you are trying to do. Much of it sounds like what the wall tool can do already. Wall accessories can add to that, and then there is the API for really advanced functions.F. wrote:I want to make a library with special walls, slabs and roofs, using layers of different materials and with special abilities to eg. calculate the amount of a certain material used.
But what should it be good for creating walls in GDL? Wouldn't it be better to create normal walls by the wall tool and modify them by profiles, attributes, wall acessory, SEOs, or simple opening objects?
I could use an existing wall and "glue" my "special-ability" object on that, but it needs to be as user friendly as possible, meaning that downloading the library and inserting the object, assigning it to a given wall, should be enough to make the whole thing work...
- Jeppe
2007-04-12 05:25 PM
Matthew wrote:I want to embed a companys products into a wall and distribute that wall. This way, the company products can be distributed (and thereby branded) as a useful, feature-rich object in archicad. But it need to be as easy to use as "standard"-walls.
2007-04-12 09:27 PM
GDL-scripts that make composites.If we talk about the same: There is no way to create composites by GDL. One missing point in the attribute commands section IMHO.
2007-04-13 07:52 AM
F. wrote:Ok, but than it sounds like Jeppe needing an API. Tepro (in Sweden) have use/build an API for placing their products on walls.GDL-scripts that make composites.If we talk about the same: There is no way to create composites by GDL. One missing point in the attribute commands section IMHO.
Your project sounds too big to solve in GDL. I think you would have to make it min. as API. Have you thought of using favourites instead?
2007-04-18 11:56 PM
