man sitting 2 14
using this new object, with the 3D view marquee'd it doesn't show in the window but if i show all or show only selection it does. anyone had this problem? is it the object or a funny setting somewhere, the old standing up people work fine.
cheers
2 Replies 2
I have seen this problem before with other objects in earlier versions.
I think this has to do with the Marquee not sensing the object for some reason.
ztaskai
Graphisoft Alumni
Graphisoft Alumni
There's a reason for this faulty behavior. When an object has a small modelling bug, the automatic correction features in ArchiCAD make it display correctly in 3D. But when it comes to cutting this slightly incorrect model, the cutting algorithm reveals the problem and it can't fix it.
All in all, this object has a modelling bug which I entered into our bugtracking records.
Thanks for highlighting the problem for us. I'm sorry about your inconvenience.
Regs,
Zsolt Táskai
ArchiCAD Development - GDL Team
AC13, AC14 and upwards...
