Kedves Balasz,
I’m not sure I well understood your question but let me try to answer it in some way…
I used a workaround in order to solve this trouble on a little library I created in the past.
These collection of furniture had to use only those materials (I mean the factory materials!) which, of course, aren’t in the default ArchiCAD settings.
1. I created a master gdl script where I defined those material (quite simple!).
2. Instead of material type parameter (for handling the object material) I used a string type parameter
3. In the object parameter script I defined (using the VALUE statement) the range of material which could be used with that parameter (string parameters : string values)
4. Before the creation of the body I inserted a MATERIAL statement that used the string value
In this way, the user could select only those materials and the requested material are always automatically generated by the master gdl script…
If you need further detail on this issue (only if it is related with what you are looking for…) please don’t hesitate to directly contact me at my personal e-mail address.
baratsaggal
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
