metal door :(
Ok so I'm using, or trying to use the metal door that came in the new AC11 library package. It's the GS Door 10_metal object.
Everything is fine except for something in 3d. I checked all the scripts, and the 3d one reports: "Fill not found at line 71 in the 3d script of file D1 Metal 11.gsm" and a few others along similar lines. After that it says:
SECT_FILL gs_fsect, gs_sfbpen, gs_sfpen, gs_frame_pen
I guess these are the fills it's complaining about.
I need a door for my bathrooms! Help
4 REPLIES 4
Thomas Holm
Tip: Use a wooden door and change its material. (No one will notice
Well for the bathrooms I found there was a preset bathroom stall partition object.
But still! I tried employing a standard interior wooden door, and it looks just dandy in plan, but when I go to 3d it gives me angry errors!
Am I the only one? What the heck?
Sometimes i have this problem and discover that i have the same GDL loaded in 2 different libraries.
