Sorry for the exclusion of an image. This is a 1/4 scale section, 120'-0" long, so I suspect the jpeg will be small. Anyway, the problem is the metal roof deck, in green, does not slope (a limitation of Profiler). I used the deck profile to extrude a 4'-0" wide deck (x direction), 120'-0" long (z direction) and 1 1/2" high(y direction). If I sloped the deck profile itself (y), and the roof sloped in that direction, then no problem. In this case the roof slope is perpendicular to the roof deck profile (z direction). Profiler generated a GDL script, but I can't figure out how to rotate it in the script, not to mention how to slope it in the correct direction.
I can send a separate email if this doesn't work so that you could see the jpeg better. I also have a short cross section perpendicular to this one showing the metal deck profile, but can't figure how to attach it to this.
I read earlier posts that said archiFORMA would do the trick, but can't find it for ac7.0.
Thanks for any help.
Chris
AC7.0r3v3, Macos9.1, ppc8500/180, 288 MB RAM, 4 GB hd
