2024-08-23 04:17 PM
Hi, I recently updated to Archicad 26, and for some reason when I open up an existing Archicad 26 project, I am missing the "Section Part marker_NCS 26.gsm" and the "NCS Drawing Title 2 26.gsm". These two library parts are commonly used in projects in our office.
Could someone please tell me how to resolve this issue? I don't know how to relink them, or where to look for them.
Thank you!
Operating system used: Mac Intel-based Sonoma
Solved! Go to Solution.
13 hours ago
You may have opened the file in 29 and removed the model, but that does not make it a native 29 file.
It will still be based on the old version.
So, as Ling mentioned, if you have old favorites that reference old objects, they will be missing.
What does the warning section in your library manager say?
To start a truly version 29 file, it needs to be based on a default 29 template.
Otherwise look in the Help documentation for the section about migrating old files.
13 hours ago
In particular ... https://community.graphisoft.com/t5/Libraries-objects/Migration-Options-for-Archicad-28-and-Later-Mo...
