missing macro for double hung window
I'm using ArchiCAD 18 and inserting the ArchiCAD double hung window. When I try and generate a 3D view I get an error message that I believe means that I am missing a macro. The message is: "File not found at line 3118 in 3D script of the file Casement_rect_usa.gsm."
Is there a way I can get the missing macro? and where would I place it since the macro files are container files?
Thanks
1 Reply 1
David Maudlin
Douglas:
Check the error message again, it probably says FILL not found. You will need to go through the parameters for the double hung window and find where there is a MISSING or ? for a Fill selection.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
