‎2016-04-0810:40 PM - last edited on ‎2023-05-2412:30 PM by Rubia Torres
‎2016-04-0810:40 PM
I'm using ArchiCAD 18 and inserting the ArchiCAD double hung window. When I try and generate a 3D view I get an error message that I believe means that I am missing a macro. The message is: "File not found at line 3118 in 3D script of the file Casement_rect_usa.gsm."
Is there a way I can get the missing macro? and where would I place it since the macro files are container files?
Check the error message again, it probably says FILL not found. You will need to go through the parameters for the double hung window and find where there is a MISSING or ? for a Fill selection.
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
