no Libraries
I just downloaded archicad 15( I haven’t used archicad previously), but I don’t have any libraries ( toilets, beds etc.).
Is this something I need to download separately or has there been an error?
Thanks
7 Replies 7
You must first load AC 15 Library:
File / Libraries and Objects / Library Manager... / Add... / select the folder
ArchiCAD Library 15 / pick the button Choose / pick OK.
Thanks for your help,
I followed your directions (they were really clear, which helped) but i couldnt find a library folder, any idea as to where it would be?
Thanks again
For a 64-bit Windows 7 the install path for ArchiCAD is (I suppose you didn´t change it):
C:\Program Files\Graphisoft\ArchiCAD 15\ArchiCAD Library 15
You should add your signature to the Profile!
nope i didn't change it, but its not there. i have vista 32 bit ( i assume thats what you ment by signiture) could that be why?
Do you have this path:
C:\Program Files\Graphisoft...?
Or is your ArchiCAD a Network version ?....In this case the Library is not on your computer!
thanks for your reply. it doesnt seem to be on my computer. in which case how do i get it?
Press the button "Windows" on the left bottom of the keyboard, then All Programs/Graphisoft/ArchiCAD 15/ArchiCAD 15, right click on your mouse and select Properties. In the pop-up window yo will see the full path of the program.
