object cutplane or cutplane object
Could some one let me know what the best practice if one to issue a cutplane before or after a object is created?
4 REPLIES 4
TomWaltz
Can you be a little more specific? I'm not sure what you are asking.
Tom Waltz
Wondering is it better to issue a cutplane before the object or create a object then issue a cutplane? Just curious.
Example:
Block 1,1,1
cutplane 90
cutend
or
cutplane 90
block 1,1,1
cutend
TomWaltz
CUTPLANE/CUTEND is an inclusive command pair, just like IF/ENDIF. It only has an effect on things inside it.
Your first sequence would not have any effect on the block.
Tom Waltz
Thanks for the help.
