‎2011-04-17 07:24 PM
‎2011-04-18 04:10 AM
‎2011-04-19 12:31 AM
‎2011-04-19 03:37 AM
Doug wrote:It maybe that as your dongle's software has been upgraded AC 7 etc no longer recognizes them?
Greetings
I have some older downloaded GDL objects that won't open in Archicad 12 (or even 10) that I'd like to recover. I've found the "file converters" that GraphiSoft has posted at:
http://www.graphisoft.com/support/archicad/downloads/Fileconverter.html
and downloaded the 7.0 and 9.0 USA packages. The page says (for 9.0 at least) that it should run with the green WibuKey, which I do have attached (and it's working for 12).
Both 7.0 & 9.0 start in demo mode?
Can anyone suggest what I may be overlooking. It must work somehow.
I've sniffed around the forum but have found this topic yet. Sorry if it's been covered.
Running OS-X 10.5.8 on a dual 2 GHz PPC G5.
Thanks in advance.
Doug
‎2011-04-19 03:45 AM
Doug wrote:I'm not sure what is going on here.
When I try to open these library parts directly in 12, I get an error message, "Unknown document version. Cannot read library part: <name> Certainly they were never opened in a newer version.
‎2011-04-19 03:54 AM
‎2011-04-19 06:39 AM
‎2011-04-19 06:48 AM
