? on For Next Loops
222: !BRICK TIES
FOR dist=0 TO 30' STEP brick_tie
ADDx dist
GOSUB 111
NEXT dist
RETURN
Will this work in an object? It's just putting 1 in and that's it. The brick_tie is a parameter for a length. GOSUB 111 is the actual lines for the brick tie.
Thanks for any help,
Michele
17 REPLIES 17
I forgot to mention this is in the 2D script window - It's not a 3D object only 2D.
Thanks,
Michele
Michele,
It should work.
Why don't you try it and see.
Del the addx transformations
before return.
Peter Devlin
I think there was an error in the GOSUB routine (along w/ other errors) but it's working now. A little trial & error goes a long way.
Thanks,
Michele
It seems that all I do is a lot of trial and error
Peter Devlin
TomWaltz
Probably not. For/Next works best with integer counters. I am betting you could end up with fractions/decimals pretty easily with this.
I would go with more of a WHILE/DO. like
WHILE dist < 30'-0" DO....
dist = dist + bricktie
ENDWHILE
Tom Waltz
Hello Tom,
Could you tell us what happens if
you end up with fractions/decimals.
Until two days ago I thought
for loops could only work with integers
but now I'm not so sure.
Thanks,
Peter Devlin
TomWaltz
I couldn't say for sure with Archicad, but most programming books I've ever seen tell you to avoid it since you cannot predict how the program will respond.
Tom Waltz
Hello Tom,
That was my impression also until, as I said, two days ago.
You mentioned once that you were studying C++.
Does the C++ for loop have the "step" part like GDL ?
It occurs to me that maybe some computer languages
may not have "step" and in that case only integers can be used.
I did a little test using the piece of code using a for loop on
page 1.26 of the GDL Cookbook 3. I tried to force the for loop
to use fractional values and calculate fractional values and
it seemed like there was no problem. The result were always
what you would expect.
Just a few thoughts,
Peter Devlin
TomWaltz
Peter wrote:
Hello Tom,
Peter Devlin
Honestly, I've not used any C++ for almost a year... I think there was, but I cannot say for sure from memory and I'm too lazy to look it up right now 🙂
Tom Waltz
