ā2014-10-27 01:54 PM
ā2014-11-19 08:10 PM
ā2014-11-19 11:28 PM
ā2014-11-20 05:19 PM
ā2014-11-21 07:11 AM
ā2014-11-21 01:07 PM
Hmooslechner wrote:Hi Hmooslechner.
Hi Mariosmic!
Thx for the flowers..
Some ideas to Your polyline:
ā2014-11-21 01:51 PM
ā2014-11-21 04:35 PM
Hmooslechner wrote:
They made a function-change possible by using the normal object-dialog. That is a little bit "stone-age" in my opinion...
My idea goes this way: (not really my idea - it has been done similar in the random city object)
Place a little pictogram near the polyline in the drawing-editor - with a hotspot-switch. This should be possible to be turnd off after the operations.
If the switch is in the normal edit-field - the edit of the cornerpoints is possible.
If the switch is in the field for "growing" - the same hotspot works for growing of the polygone-shape
If the switch is in the field for segment-growing - the middle-point grows just this one segment.
If the switch is in the field for Corner-rounding - the same klick on the hotspot rounds the corner
If the switch is in the field for rounding the segments - the middlepoint works to round it like Your functionality.
This could be very near the normal polygon-behaviour in Archicad like editing slabs or hatches with the pet-pal.
The next thing i am thinking of - is: to use just one simple parameter for one polygon - one array with three dimensions for x, y, z and maybe some Flags for function changes - but that is future-music.. So it would be much easier to work with it in GDL - to copy the functionality for more open polygons in one GDL
In my last objects where i made three open polygons-profiles following an open path - it had to copy Esteban ramos-code in the 2D-GDL, the Masterscript, the Parameter-script and the 3D-Script and had to change the name of every parameter for each different polygone x+y (+ Z). The possibility of making some mistakes is very high - and very time-consuming for each profile.
Just one parameter-Array for all of this should be much easier and easier to understand... to alter and to use with less mistakes!
ā2014-11-24 03:24 PM
ā2014-12-01 02:19 PM
Hmooslechner wrote:Thank-you Hmooslechner. I'm working on many other parameters. It's very hard. But it seems there are not obstacles in the languages. It needs only time.
Hi Mariosmic!
Your Railing-part is obviously the best railing-Object for Stairs i have seen so far!
I will spread Your Video - in our region - to raise Your chances for selling it - if You like! Now its all going the right direction! i hope You are very proud of this!
ā2015-01-08 01:50 PM
