ā2003-12-23 02:36 AM
ā2003-12-23 05:40 AM
ā2003-12-23 05:46 AM
ā2003-12-23 06:15 AM
ā2003-12-23 07:02 AM
ā2003-12-23 07:20 AM
ā2003-12-23 09:58 AM
Aussie wrote:If you're using AC8, you should have a look at the boolean operation in GDL scripts : it should be even easier to manipulate... (I've never managed very well the PUT and GET command
Hi anyone know a trick to script a prism command so that an inserted hole is on or off? Making a zero sized hole obviously gives an error
ā2003-12-24 02:41 AM
ā2003-12-25 12:05 AM
ā2003-12-29 06:06 AM
