parametric chair difficulties
Following the 'Intro to object making" guide I have reached to a point with my gdl object where I can't understand the mistake I made, which causes a error message concerning line 31, at the master script check.
I need some help here.All I did was to follow,step-by-step,the exact instructions of the guide.
here is the master script
!Pop down Menu
bv0="No leg braces"
bv1="O brace"
bv2="H brace"
VALUES "bracetype", bv0, bv1, bv2
IF bracetype=bv0 THEN
brace=0
ELSE
brace=1
ENDIF
MATERIAL lmat
IF bakon=0 THEN arms=0
IF bakon=0 THEN strot=0
!Menu for Chair
cv0='Customised chair'
cv1='Foot stool'
cv2='Nursery chair'
cv3='Piano stool'
cv4='Dining chair'
cv5='Dining armchair'
cv6='Kitchen stool'
cv7='Bar stool'
VALUES 'chairtype', cv0,cv1,cv2,cv3,cv4,cv5,cv6,cv7
IF chairtype<>cv0 THEN
!Grey out custom parameters
LOCK 'stlgth','stwidth','stheight'
LOCK 'lsec','backsec'
LOCK 'bakon','bracetype','backheight','arms'
ENDIF
IF chairtype =cv1 THEN !Footstool
stlgth=0.35: stwidth=0.30: stheight=0.28:
lsec=0.04: backsec=0.04: arms=0
bakon=0: bracetype=bv0
ENDIF
IF chairtype =cv2 THEN !Nursery chair
stlgth=0.30: stwidth=0.35: stheight=0.32:
lsec=0.04: frsec=0.04: arms=0
bakon=1: bracetype=bv0: bheight=0.5
ENDIF
IF chairtype =cv3 THEN !Piano stool
stlgth=0.45: stwidth=0.40: stheight=0.45:
lsec=0.05: backsec=0.1: arms=0
ENDIF
IF chairtype =cv4 THEN !Dining chair
lsec=0.05: backsec=0.05: arms=0
bakon=1: bracetype=bv1: backheight=0.55
ENDIF
IF chairtype =cv5 THEN !Dining armchair
stlgth=0.50: stwidth=0.45: stheight=0.45:
lsec=0.05: backsec=0.05: arms=1
bakon=1: bracetype=bv1: backheight=0.65
ENDIF
IF chairtype =cv6 THEN !Kitchen stool
stlgth=0.35: stwidth=0.40: stheight=0.60:
bakon=0: bracetype=bv2
ENDIF
IF chairtyp =cv7 THEN !Bar stool
stlgth=0.35: stwidth=0.40: stheight=0.65:
bakon=1: bracetype=bv2: backheight=0.3
ENDIF
and here is the 3D script
PEN 1
RESOL 12
!All the legs
MATERIAL lmat
!lsec/3 is the down leg diameter
CONE lgheight, lsec/3, lsec/2, 90,90
ADDx stlgth
ADDy stwidth
ADDx -stlgth
DEL 3
!seat and upholstery
ADDz stheight
ROTx -3
BLOCK stlgth,stwidth,stthick
MATERIAL stmat
ADD 0.025,0.025,0.045
BLOCK stmatlth,stmatwdth,stmatthick
DEL 3
!Back Legs, panel and upholstery
IF bakon THEN
MATERIAL framat
ADD 0,stwidth,stheight + stthick + stmatthick
CONE backheight - 0.1,0.03,0.02, 90,90 !leg
ADDx stlgth
DEL 2
ADD 0,stwidth-0.02,backheight !back panel
ROTx -2
BLOCK 0.45,backsec,0.35
MATERIAL backmat
ADD 0.05,-0.01,0.02 !back material
BLOCK 0.35,0.01,0.30
DEL 3
ENDIF
MATERIAL lmat
!Braces front to rear
IF bracetype=bv2 THEN !H Brace
ADDz lgheight/3
ADDx lsec/8
ROTx -90
CONE 0.5/2,lsec/4,lsec/3,90,90
ADDz 0.5/2
CONE 0.5/2,lsec/3,lsec/4,90,90
DEL 4
ADD stlgth,lsec/8,lgheight/3
ROTx -90
CONE lgheight/2,lsec/4,lsec/3,90,90
ADDz lgheight/2
CONE lgheight/2,lsec/3,lsec/4,90,90
DEL 3
ADD 0,0.25,lgheight/3
ROTz -90
ROTx -90
CONE stlgth/2,lsec/4,lsec/3,90,90
ADDz stlgth/2
CONE stlgth/2,lsec/3,lsec/4,90,90
DEL 4
ENDIF !brace=bv2
IF bracetype=bv1 THEN !O Brace
ADD 0,0,stheight/3
ROTz -90
ROTx -90
ADDz stlgth/2
DEL 4
ADD 0,stwidth,stheight/3
ROTz -90
ROTx -90
ADDz stlgth/2
DEL 4
ADDZ stheight/3
ROTX -90
CONE stwidth/2,lsec/4,lsec/3,90,90
ADDz stwidth/2
CONE stwidth/2,lsec/3,lsec/4,90,90
DEL 3
ADDx stlgth
ADDz stheight/3
ROTx -90
ADDz stwidth/2
DEL 4
ENDIF
!arms option
IF arms THEN
ADDz backheight !left
ADDy -backheight/6
ROTx -90
MULy 0.5 !Squash the arm cone to an ellipse
CONE stwidth + (backheight/6),lsec/2,lsec/3,90,90
DEL 4
ADDz stheight + stthick + stmatthick
CONE (backheight/3) - 0.06 , lsec/2 , lsec/3 , 90 , 90
DEL 1
ADDx stlgth
ADDz backheight !right
ADDy -backheight/6
ROTx -90
DEL 5
ADDx stlgth
DEL 2
ENDIF
10 REPLIES 10
Seems to work OK for me. Have you added "chairtype" to the list of parameters? I only get an error if this parameter doesn't exist.
I also noticed you have mis-spelled chairtyp =cv7 in the Masterscript. Should be chairtype =cv7.
Hope that sorts it!
thank you for your time,however the problem was the double braces i did't use around "chairtype". it should be
if "chairtype"<>cv0...
if "chairtype"=cv1...
..and so on..
now the problem is that the 3d view of my object does not react to any change of the value of "chairtype"...
i am wondering,does some part of the script need to be written inside the 3d script and some other part inside the master script? is that my mistake?
deinan,
where you have part of the script like this
ENDIF
are all these parameters? if so you will need to change the script to read like this
parameters stlgth=0.35, stwidth=0.30, stheight=0.28,
lsec=0.04, backsec=0.04, arms=0,
bakon=0, bracetype=bv0
ENDIF
This applies to every other parameter you are trying to change its value in the Parameter or Master Script tabs. If it is a variable however, it does not need to use the parameter command.
Hope that helps...
some of them are variables while some others are parametres.I corrected the script where parameters were involved.still it doesn't work, plus there is an error message,saying that i am using non-necessary symbols at certain places.i couldn't find any of those symbols.
here is an example
IF "chairtype" =cv1 THEN !Footstool
PARAMETERS arms=0, bakon=0, bracetype=bv0
ENDIF
the error message indicates the second line
any ideas?
Where you dont use the PARAMETERS command you can use your original script. So replace your , with : as below.
ENDIF
It may be a personal preference but i would actually write the script like this, much easier to read once you have to find it and read it quickly amoungst hundreds of lines of script.
!Footstool
if "chairtype" =cv1 then
stlgth=0.35
stwidth=0.30
stheight=0.28
lsec=0.04
backsec=0.04
parameters arms=0,
bakon=0,
bracetype=bv0
endif
Thank you,i corrected the symbols,there is no error message now.Still my model doesn't respond though.. I am sending again the current scripts and an image of my variables and parametres,maybe you can help me find the mistake i am making as a newbie..
3d script
PEN 1
RESOL 12
!All the legs
MATERIAL lmat
ADDx stlgth
ADDy stwidth
ADDx -stlgth
DEL 3
ADDz stheight
ROTx -3
MATERIAL stmat
DEL 3
IF bakon THEN
MATERIAL framat
ADDx stlgth
DEL 2
ROTx -2
BLOCK backlgth,backsec,backlgth-10
MATERIAL backmat
DEL 3
ENDIF
MATERIAL lmat
ADDz lgheight/3
ADDx lsec/8
ROTx -90
ADDz 0.5/2
DEL 4
ROTx -90
ADDz lgheight/2
DEL 3
ROTz -90
ROTx -90
ADDz stlgth/2
DEL 4
ENDIF !brace=bv2
ADD 0,0,stheight/3
ROTz -90
ROTx -90
ADDz stlgth/2
DEL 4
ROTz -90
ROTx -90
ADDz stlgth/2
DEL 4
ADDZ stheight/3
ROTX -90
ADDz stwidth/2
DEL 3
ADDx stlgth
ADDz stheight/3
ROTx -90
ADDz stwidth/2
DEL 4
ENDIF
!arms option
IF arms THEN
ADDy -backheight/6
ROTx -90
DEL 4
DEL 1
ADDx stlgth
ADDy -backheight/6
ROTx -90
DEL 5
ADDx stlgth
DEL 2
ENDIF
master script
!Pop down Menu
bv0="No leg braces"
bv1="O brace"
bv2="H brace"
brace=0
ELSE
brace=1
ENDIF
MATERIAL lmat
brace=0
ELSE
brace=1
ENDIF
MATERIAL lmat
IF bakon=0 THEN arms=0: strot=0
!Menu for Chair
cv0="Customised chair"
cv1="Foot stool"
cv2="Nursery chair"
cv3="Piano stool"
cv4="Dining chair"
cv5="Dining armchair"
cv6="Kitchen stool"
cv7="Bar stool"
VALUES "chairtype" ,cv0,cv1,cv2,cv3,cv4,cv5,cv6,cv7
!Customized chair
IF "chairtype"<>cv0 THEN
LOCK 'stlgth',
'stwidth',
'stheight',
'lsec',
'backsec' ,
'bakon',
'bracetype',
'backheight',
'arms'
ENDIF
!Footstool
stlgth=0.35
stwidth=0.30
stheight=0.28
lsec=0.04
backsec=0.04
ENDIF
!Nursery chair
IF "chairtype" =cv2 THEN
stlgth=0.30
stwidth=0.35
stheight=0.32
lsec=0.04
frsec=0.04
bheight=0.5
PARAMETERS arms=0, bakon=1, bracetype=bv0
ENDIF
!Piano stool
IF "chairtype" =cv3 THEN
stlgth=0.45
stwidth=0.40
stheight=0.45
lsec=0.05
backsec=0.1
ENDIF
!Dining chair
IF "chairtype" =cv4 THEN
stlgth=0.45
stwidth=0.40
stheight=0.45
lsec=0.05
backsec=0.05
backheight=0.55
PARAMETERS bakon=1, bracetype=bv1, arms=0
ENDIF
!Dining armchair
IF "chairtype" =cv5 THEN
stlgth=0.50
stwidth=0.45
stheight=0.45
lsec=0.05
backsec=0.05
backheight=0.65
PARAMETERS bakon=1, bracetype=bv1, arms=1
ENDIF
!Kitchen stool
IF "chairtype" =cv6 THEN
stlgth=0.35
stwidth=0.40
stheight=0.60
lsec=0.05
backsec=0.05
PARAMETERS bakon=0, bracetype=bv2, arms=0
ENDIF
!Bar stool
IF "chairtype" =cv7 THEN !Bar stool
stlgth=0.35
stwidth=0.40
stheight=0.65
lsec=0.05
backsec=0.05
backheight=0.3
PARAMETERS bakon=1, bracetype=bv2, arms=0
ENDIF
the image
In trying to run the script there seems to be alot of errors. You can check these by clicking on "check script" at the top of each script. It will tell you the line number where the problem is. I wont try and fix them all but will leave it with you to go through them all.
In terms of changing the "chair type" there were a few places where you had the parameters and variable command mixed up. Any changes you want to make to a parameter listed in the object you need to use the PARAMATER command. Any not listed as parameters you dont need it. I have fixed these and rewritten this part so the values of the chair type work correctly
IF bakon=0 THEN !!!!!!!!!!!!!!!Need to put on separate lines and missing endif
arms=0
strot=0
ENDIF
!!Menu for Chair
!cv0="Customised chair"
!cv1="Foot stool"
!cv2="Nursery chair"
!cv3="Piano stool"
!cv4="Dining chair"
!cv5="Dining armchair"
!cv6="Kitchen stool"
!cv7="Bar stool"
!VALUES "chairtype" ,cv0,cv1,cv2,cv3,cv4,cv5,cv6,cv7
!Rewrite the above to
VALUES "chairtype" "Customised chair",
"Foot stool",
"Nursery chair",
"Piano stool",
"Dining chair",
"Dining armchair",
"Kitchen stool",
"Bar stool"
if chairtype="Customised chair" then chairtypefinal="cv0"
if chairtype="Foot stool" then chairtypefinal="cv1"
if chairtype="Nursery chair" then chairtypefinal="cv2"
if chairtype="Piano stool" then chairtypefinal="cv3"
if chairtype="Dining chair" then chairtypefinal="cv4"
if chairtype="Dining armchair" then chairtypefinal="cv5"
if chairtype="Kitchen stool" then chairtypefinal="cv6"
if chairtype="Bar stool" then chairtypefinal="cv7"
!Customized chair
IF chairtypefinal <> "cv0" THEN !!!!!!!!!!!!remove brackets and changed variable
LOCK 'stlgth',
'stwidth',
'stheight',
'lsec',
'backsec' ,
'bakon',
'bracetype',
'backheight',
'arms'
ENDIF
!Footstool
IF chairtypefinal = "cv1" THEN !!!!!!!!!!!!changed
PARAMETERS stlgth=0.35,
stwidth=0.30,
stheight=0.28,
lsec=0.04,
backsec=0.04,
arms=0,
bakon=0,
bracetype=bv0
ENDIF
!Nursery chair
IF chairtypefinal ="cv2" THEN !!!!!!!!!!!!changed
PARAMETERS stlgth=0.30,
stwidth=0.35,
stheight=0.32,
lsec=0.04,
arms=0,
bakon=1,
bracetype=bv0
bheight=0.5
frsec=0.04
ENDIF
!Piano stool
IF chairtypefinal ="cv3" THEN !!!!!!!!!!!!changed
PARAMETERS stlgth=0.45,
stwidth=0.40,
stheight=0.45,
lsec=0.05 ,
backsec=0.1 ,
arms=0,
bakon=0,
bracetype=bv0
ENDIF
!Dining chair
IF chairtypefinal ="cv4" THEN !!!!!!!!!!!!changed
stwidth=0.40,
stheight=0.45,
lsec=0.05,
backsec=0.05,
backheight=0.55,
bakon=1,
bracetype=bv1,
arms=0
ENDIF
!Dining armchair
IF chairtypefinal ="cv5" THEN !!!!!!!!!!!!changed
PARAMETERS stlgth=0.50,
stwidth=0.45,
stheight=0.45,
lsec=0.05,
backsec=0.05,
backheight=0.65,
bakon=1,
bracetype=bv1,
arms=1
ENDIF
!Kitchen stool
IF chairtypefinal ="cv6" THEN !!!!!!!!!!!!changed
stwidth=0.40,
stheight=0.60,
lsec=0.05,
backsec=0.05,
bakon=0,
bracetype=bv2,
arms=0
ENDIF
!Bar stool
IF chairtypefinal ="cv7" THEN !Bar stool !!!!!!!!!!!!changed
stwidth=0.40,
stheight=0.65,
lsec=0.05,
backsec=0.05,
backheight=0.3,
bakon=1,
bracetype=bv2,
arms=0
ENDIF
Good luck!
Thank you for your assistance. However i did chech my script several times and the answer was "the gdl script is ok". Now that is strange. I will check the script carefuly and fix it as you say.I confess that i didn'it know some of the rules ,nor did i read them anywhere inside my gdl guide. I am not very satisfied with the guide since i needed external help several times.Anyway,I am going through the script once again.Hope it works!
