Thank you,i corrected the symbols,there is no error message now.Still my model doesn't respond though.. I am sending again the current scripts and an image of my variables and parametres,maybe you can help me find the mistake i am making as a newbie..
3d script
PEN 1
RESOL 12
!All the legs
MATERIAL lmat
!lsec/3 is the down leg diameter
CONE lgheight, lsec/3, lsec/2, 90,90
ADDx stlgth
ADDy stwidth
ADDx -stlgth
DEL 3
!seat and upholstery
ADDz stheight
ROTx -3
BLOCK stlgth,stwidth,stthick
MATERIAL stmat
ADD 0.025,0.025,0.045
BLOCK stmatlth,stmatwdth,stmatthick
DEL 3
!Back Legs, panel and upholstery
IF bakon THEN
MATERIAL framat
ADD 0,stwidth,stheight + stthick + stmatthick
CONE backheight - 0.1,0.03,0.02, 90,90 !leg
ADDx stlgth
DEL 2
ADD 0,stwidth-0.02,backheight !back panel
ROTx -2
BLOCK backlgth,backsec,backlgth-10
MATERIAL backmat
ADD 0.05,-0.01,0.02 !back material
BLOCK 0.35,0.01,0.30
DEL 3
ENDIF
MATERIAL lmat
!Braces front to rear
IF bracetype=bv2 THEN !H Brace
ADDz lgheight/3
ADDx lsec/8
ROTx -90
CONE 0.5/2,lsec/4,lsec/3,90,90
ADDz 0.5/2
CONE 0.5/2,lsec/3,lsec/4,90,90
DEL 4
ADD stlgth,lsec/8,lgheight/3
ROTx -90
CONE lgheight/2,lsec/4,lsec/3,90,90
ADDz lgheight/2
CONE lgheight/2,lsec/3,lsec/4,90,90
DEL 3
ADD 0,0.25,lgheight/3
ROTz -90
ROTx -90
CONE stlgth/2,lsec/4,lsec/3,90,90
ADDz stlgth/2
CONE stlgth/2,lsec/3,lsec/4,90,90
DEL 4
ENDIF !brace=bv2
IF bracetype=bv1 THEN !O Brace
ADD 0,0,stheight/3
ROTz -90
ROTx -90
ADDz stlgth/2
DEL 4
ADD 0,stwidth,stheight/3
ROTz -90
ROTx -90
ADDz stlgth/2
DEL 4
ADDZ stheight/3
ROTX -90
CONE stwidth/2,lsec/4,lsec/3,90,90
ADDz stwidth/2
CONE stwidth/2,lsec/3,lsec/4,90,90
DEL 3
ADDx stlgth
ADDz stheight/3
ROTx -90
ADDz stwidth/2
DEL 4
ENDIF
!arms option
IF arms THEN
ADDz backheight !left
ADDy -backheight/6
ROTx -90
MULy 0.5 !Squash the arm cone to an ellipse
CONE stwidth + (backheight/6),lsec/2,lsec/3,90,90
DEL 4
ADDz stheight + stthick + stmatthick
CONE (backheight/3) - 0.06 , lsec/2 , lsec/3 , 90 , 90
DEL 1
ADDx stlgth
ADDz backheight !right
ADDy -backheight/6
ROTx -90
DEL 5
ADDx stlgth
DEL 2
ENDIF
master script
!Pop down Menu
bv0="No leg braces"
bv1="O brace"
bv2="H brace"
VALUES "bracetype", bv0, bv1, bv2
IF bracetype=bv0 THEN
brace=0
ELSE
brace=1
ENDIF
MATERIAL lmat
brace=0
ELSE
brace=1
ENDIF
MATERIAL lmat
IF bakon=0 THEN arms=0: strot=0
!Menu for Chair
cv0="Customised chair"
cv1="Foot stool"
cv2="Nursery chair"
cv3="Piano stool"
cv4="Dining chair"
cv5="Dining armchair"
cv6="Kitchen stool"
cv7="Bar stool"
VALUES "chairtype" ,cv0,cv1,cv2,cv3,cv4,cv5,cv6,cv7
!Customized chair
IF "chairtype"<>cv0 THEN
!Grey out custom parameters
LOCK 'stlgth',
'stwidth',
'stheight',
'lsec',
'backsec' ,
'bakon',
'bracetype',
'backheight',
'arms'
ENDIF
!Footstool
IF "chairtype" =cv1 THEN
stlgth=0.35
stwidth=0.30
stheight=0.28
lsec=0.04
backsec=0.04
PARAMETERS arms=0, bakon=0, bracetype=bv0
ENDIF
!Nursery chair
IF "chairtype" =cv2 THEN
stlgth=0.30
stwidth=0.35
stheight=0.32
lsec=0.04
frsec=0.04
bheight=0.5
PARAMETERS arms=0, bakon=1, bracetype=bv0
ENDIF
!Piano stool
IF "chairtype" =cv3 THEN
stlgth=0.45
stwidth=0.40
stheight=0.45
lsec=0.05
backsec=0.1
ENDIF
!Dining chair
IF "chairtype" =cv4 THEN
stlgth=0.45
stwidth=0.40
stheight=0.45
lsec=0.05
backsec=0.05
backheight=0.55
PARAMETERS bakon=1, bracetype=bv1, arms=0
ENDIF
!Dining armchair
IF "chairtype" =cv5 THEN
stlgth=0.50
stwidth=0.45
stheight=0.45
lsec=0.05
backsec=0.05
backheight=0.65
PARAMETERS bakon=1, bracetype=bv1, arms=1
ENDIF
!Kitchen stool
IF "chairtype" =cv6 THEN
stlgth=0.35
stwidth=0.40
stheight=0.60
lsec=0.05
backsec=0.05
PARAMETERS bakon=0, bracetype=bv2, arms=0
ENDIF
!Bar stool
IF "chairtype" =cv7 THEN !Bar stool
stlgth=0.35
stwidth=0.40
stheight=0.65
lsec=0.05
backsec=0.05
backheight=0.3
PARAMETERS bakon=1, bracetype=bv2, arms=0
ENDIF
