paramiter width &leanth
If i give the measurement to exterior window or door .
It is still not clear what you mean.
In the US width and height usually refers to the size of the door panel or panels alone (excluding the jambs) but for windows they refer to the unit dimensions (including the jamb but excluding casings). Length is typically not meaningful in these cases.
Please note that it is not necessary (nor appropriate) to repost in a new topic. You should reply in the original.
