perimeter - plaster and thermal insulation - GDL
Hmooslechner
I recently developt a GDL-part for the perimeter-plaster and thermal insulation-layers with the possibility to alter the z-hights.
It is based on the polygon-functionality of arch. esteban ramos as in the former Elements i showd you recently.
It is meant for beeng able to set the perimeter-plasterhight in 3d independent from the wall - z-0.
You have to perform a solid element-substraction with prolonging down of the element from the wall above.
It is not possible, to cut out the windwos which can be situated in the cellar-wall. That You will have to do manuel by SOE from the Element.
In normal planing-situation, you will insert more than one of this Elements to your drawing to spare out the doors. In my simple example - i used just one around the whole buliding to show the functionality.
to try it till its set free fom Bimcomponents:
https://www.dropbox.com/s/q2n65nmcrfnq48p/Perimeter.pln?dl=0
Pleasy reply your recommentations!
Video - tut:
https://www.youtube.com/watch?v=JfNhe00x9H4
11 REPLIES 11
sinceV6
Well...
I had kind of the same issue. The original dynamic polyline was developed with this object in mind:
http://archicad-talk.graphisoft.com/viewtopic.php?p=220176
I needed different sizes for the parking spaces, so I figured I could just let each segment have its own size, and add as many as I needed. Worked great!
Best regards.
Hmooslechner
I just added some open Archicad-Wishes in this forum which are related to this topic! Please vote there!
http://archicad-talk.graphisoft.com/viewtopic.php?p=234465#234465
