Display malfunction of Graphisoft ID dashboard
Learn more
problem
I always have a problem, why not have a similar amount of REVIT modeling of body function, because programs are relatively free, if you can import the AC model in rhino, with a tool to identify a variety of components, not very easy to do, even without this plug-in can also be extracted from the data import
AC still have these features, but I will not use, and should be used GDL visual programming, like grasshopper same.
3 Replies 3
Eduardo Rolon
Your post is unintelligible. What is the question?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
I am seriously trying to decide if this user is someone not speaking English so he used some automatic translator, and the result is this gibberish (but then if he speaks so little English there is no use in posting on a English forum), or that this is a spam-bot that has put together sentences from words and phrases found on the forum, in which case I should just ban him.
Anyway, we will see.
Eduardo Rolon
Same doubts here (basically because he didn't register today) and that is why I didn't ban him outright.
AC29 US/INT -> AC08
another Moderator
