rob2218
Bay Window Object? Can not snap to any of it's corners? why?
I have a "bay window 17" object.
I can NOT snap to any of it's corners......WHY?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
3 Replies 3
rob2218
by the way.....here's where I can NOT snap to...in case we needed a graphics..
i>u
Edgewater, FL!
SOFTWARE VERSION:
NCornia
Graphisoft Alumni
Graphisoft Alumni
Rob,
thanks for the graphic. I tested the "W Splay Bay 17" window and there are additional nodes and graphic hotspots that should be there. I will create a case in tech support and email some details to you to investigate further.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
rob2218
please sir.....do tell how to activate those "added hotspots so's I can use them.
I also wanted to be able to "snap to intersection" on those bay window 2D lifework but if I draw a line say 'thru' the bay window glass where it intersects the bay window graphics.....i can't see to hit the "intersection" between the line and the object.
NCornia wrote:
Rob,
Best regards,
i>u
Edgewater, FL!
SOFTWARE VERSION:
