ā2006-06-27 12:20 AM
ā2006-06-27 02:41 AM
ā2006-06-27 03:47 PM
brian wrote:
In reading about libraries in version 10, the help file suggests combining the AC 10 library with whatever library you want to use for a project, and making a container file of the combination to use as the project library.
ā2006-06-27 07:33 PM
ā2006-06-27 07:50 PM
ā2006-06-28 04:06 AM
ā2006-06-28 07:52 PM
ā2006-06-28 08:19 PM
ā2006-06-28 08:26 PM
ā2006-06-29 04:39 AM
Eric wrote:Well, sort of. I'm not clear on whether you even load the AC library in your typical job...
I keep the standard AC library as-is and modify parameters through favorites mostly. I don't edit the code of the GS parts.
Is that what you were asking?
