"Elliptic Arch Window" object for AC10
Hi to everyone,
I used to make a decorative elliptic arc opening in AC 9 as per attach picture. This object was not part of the AC INT version.
Unfortynately this window object is not working with AC10. I have try copying the 2D and 3D script but in vain ( I am not at all good at GDL).
Can someone please help me to either:
1/. rewrite this GDL object for AC 10
2/. or help me to find another Elliptic Arc Window Opening
Thanks.
15 Replies 15
Peter wrote:
I am in the process of making an elliptical head opening object
that just cuts a hole with correct shape in a wall.
Thank you very much.
Please refer to the window library I posted. In AC9 it is possible to show the Ellipse in 2D.
If you would consider this, it will be great.
Peter wrote:
I am puzzled about why whoever wrote "W ellipse Arch Opening"
did not make an object that was a true ellipse.
Frank Beister
Maybe it is a wrong translation for a three centered arch, which is part of our German library.
Peter Devlin
Peter,
Its a matter of long standing tradtion and practicality when it comes to design and construction...Ellipses are approximated for this reason. here's a good link to further describe what I'm saying
http://www.nexusjournal.com/conferences/N2000-Rosin.html
Several years ago I scripted an object to do this in plan when ArchiCAD wasn't able to draw ellipses. As far as i'm concerned ArchiCAD still does not offer the ability to draw a true "approximated" ellipse...If you need one, you still have to manually construct it.
HTH,
Dan K
Any news please.
oops2,
I have completed the object for what it is worth.
It does the same thing that the "old" object does but in a deferent way.
If you want the object tell me your e-mail address and I will send it to you.
Peter Devlin
Peter wrote:
oops2,
Peter Devlin
I have sent PM you the necessary info.
Thanks
