"Special" sliding doors generating errors in 3D
I've got this series of sliding doors in my ArchiCAD libraries (v.10 and 11), and they don't work in 3D. In ONE FILE. But they work in other files. Hmmm. Any thoughts?
They're "stock" doors (I'm inept with the GDL stuffs). Am I going to have to rebuild the file completely, or can I rename it...?
3 Replies 3
Is it too late to merge the file that doesn't work into a blank project file in which it will work?
TomWaltz
Did you try resetting the door to its default parameters? What kind of wall is it being placed in?
Tom Waltz
Doors are at default parameters... placed one unchanged, straight from the library, and it did the same thing as the ones i'd sized for the project.
I'm inserting them into a simple custom composite wall.
Dunno 'bout this merge thing... will try that soon.
Thanks for your suggestions.
Today's Problem to Solve: Corner Windows.
