removing window lines
does any one know how to get rid of the lines on windows and doors in drawings that indicte which way it opens? on archicad13
thanks
9 REPLIES 9
If you mean showing opening lines in 3D window:
vistasp
Laky, you can control the opening lines via model view options.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
vistasp
Andro, for users of v.13, the option to override the MVO does not exist. This was only introduced in v.14. 😉
= v i s t a s p =
bT Square Peg
Do you mean in elevation? I think there is a global setting for this in AC14. In prior versions (as I recall) it is a setting in the parts themselves.
ArchiCAD 13+ objects can be controlled with
model view options (MVO) too. The setting is
possibly there.
Regards, Juha
vistasp
Laky, you've posted an identical question on another thread as well. Please avoid double posting.
= v i s t a s p =
bT Square Peg
I merged the two topics so now all answers are in one thread.
vistasp
Thanks Laszlo.
= v i s t a s p =
bT Square Peg
thanks everyone! i finally managed it, its under mvo!
