request master layout info
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2013-11-15 01:23 AM
2013-11-15
01:23 AM
Michael Wilson
ArchiCAD 9 - 22 (6021 AUS Full)
Win7 | 64 bit | 8Gb RAM | Intel i7 3.40 Ghz
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-11-15 07:05 PM
2013-11-15
07:05 PM
I think requesting the master size is not possible,
but the name is.
We have named our masters so that the title block
knows the size, "4x2 horizontal" for example. (One
unit is european DIN A4 210*297 mm).
Works fine.
but the name is.
Works fine.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-11-16 02:59 PM
2013-11-16
02:59 PM
wilson83:
There is a potential work around, if the object is Drawing Title type, one of its parameters is AC_LayoutRect, which is an array that gives the extents of the layout the Drawing Title is on. So you might be able to use this information to determine the size of the layout. Juha's solution is much simpler.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-11-20 03:20 AM
2013-11-20
03:20 AM
Works fine.
Juha- This was exactly what I was looking for. Do you have an example of the request script that you need to use. I'm a bit of a hack when it comes to request quotes. I just use one from another part that does what I want it to do.
Michael Wilson
