2011-11-25 06:38 PM
2011-11-26 11:00 AM
2011-11-26 11:07 AM
2011-11-26 11:14 AM
Piotr wrote:Not that.
What is the purpose of this?
If editable poly - it is easier to manage with matrix parameters...
Best Regards,
Piotr
2011-11-26 08:02 PM
2011-11-27 12:26 AM
Piotr wrote:I make a wall object for landscape, garden with slope… with z point (hotspot 3D) for each corner, with straight and curves… (I don't understand why Graphisoft did not invent a wall tool to which one can define different heights).
Again - what You are trying to achieve with the point no?
Best Regards,
Piotr
2011-11-28 07:02 PM
2011-11-28 08:51 PM
Piotr wrote:Yes, I do like that, thanks again.
To make the curve of a poly segment: add another matrix parameter: "bulge" - for all segments. Than if "bulge"changes from 0 than the poly segment will change from straight to curve, You have to calculate the arc from start and end of the segment and bulge to the circle arc in position.
Best Regards,
Piotr
