rotate door dimension
Hello.
Does anybody have a clue how I can mirror the text of the dimension marker for a door? In the picture one can see the actual door and in the background the direction in which I wish the door text to be as well.
Thank you.
Double-check to see if the Wall of the Door is really exactly horizontal.
If it is the dimensions should be looking to the left, just like the ones in the Trace Reference shown in the image.
It could be that it is off only by a fraction of a degree so it is practically not visible unless you measure it.
Thank you for the answer. That was the issue.
