saving door marker
I created door marker customizing marker settings in door selection settings. Now every time I put new door I must set it again. Is there any way to save this own marker and load it under "load other window-door marker" or to force this own marker load automatically?
4 Replies 4
TomWaltz
Do you have an office library? If not. it may be a good time to start. one:
1) Create a Folder somewhere accessible to everyone else in the office.
2) Open the Library Manager
3) browse to that folder, select it,
4) and click "Add."
5) then click "OK"
That will load the folder and any objects you have in it.
Tom Waltz
Sorry for being so retard, but I don't understand what you mean by your answer.
I try to describe it better.
I have set door marker to fit my need. While working on project without closing ArchiCAD, I can chose any other door from library and door marker in "marker settings" remain as i set it so new door will appear with that marker. But when closing and opening ArchiCAD again, as I hit door tool and select a door, it shows in marker settings default marker and I must customize it again.
I apologize about lack of ArchiCAD knowledge as well as my english.
Favorites might get what you are after. After making the changes to the door marker, save it as a favorite. If you pull up that favorite you will have all the settings as you had previously set them.
Yes. This is what I was after, thanx.
