show symbol disabled parking on 2D like in 3D
mrsneuna
how to show symbol disable parking in 2d  ?
Operating system used: Windows 10
Hi @mrsneuna,
I don't know if you are using a default Archicad library object called (Parking Place) or not.
But if you use it here're the adjustments in 2D & 3D to get the desired result, I hope that helps.
AC 27 INT 5060/WIN 11
What object are you using?
It would need to have a parameter that allows you to turn on the 2D markings.
Hi @mrsneuna,
omg, I didn't see it, thank you so much
Setup info provided by author
