2024-05-04 05:35 AM
how to show symbol disable parking in 2d ?
Operating system used: Windows 10
Solved! Go to Solution.
2024-05-06 01:25 PM - edited 2024-05-06 01:26 PM
Hi @mrsneuna,
I don't know if you are using a default Archicad library object called (Parking Place) or not.
But if you use it here're the adjustments in 2D & 3D to get the desired result, I hope that helps.
2024-05-06 04:15 AM
What object are you using?
It would need to have a parameter that allows you to turn on the 2D markings.
Hi @mrsneuna,
2024-05-07 05:17 AM
omg, I didn't see it, thank you so much
