â2011-12-15
03:45 PM
â2023-05-24
10:53 AM
Rubia Torres
â2011-12-15 08:23 PM
â2011-12-16 02:27 PM
â2011-12-16 02:30 PM
â2011-12-16 02:32 PM
â2011-12-17 04:07 PM
maryastone wrote:The answer will depend on the level of detail you want in 2D and 3D. Making the door slightly smaller than the wall and setting the wall material to your frame/track material will give a simple solution. Using beams as Stuart suggested allows you a more detailed solution, particularly if those beams are Complex Profiles.
Thanks, Dave. That's what i've done, but I'm not getting the tracks on the bottom or the top...
