slicing gdl objects
Hello everybody.
If I create a object like that:
BLOCK 2,2,2
ADDX 2
BLOCK 2,2,2
I'll have two blocks side by side. Ok, but when my section pass trough the object it will not show the line that separate the two blocks. What I need to do to have parts of objects with their profiles showed in sections, like in this case the section of the two blocks.
Thank you very much for your help.
brag,
Brazil
TomWaltz
They need to have different SECT_FILL values in order to be distinct in sections.
Tom Waltz
Yes, you can define two entirely identical fills under two separate Fill names.
One block should use one of these fills, the other one the other.
Then it will show the line.
Thank you. It works. Great!!!
brag,
Brazil
