Tom Krowka
storefront window question
How can I change the bottom mullion dept at the sill on the storefront window? There seems to be a setting for everything else except that element. I hope it's not a default that can't be changed.
Otherwise, how do you put in a storefront window. Curtain wall is a wall and won't punch a hole in the existing wall.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
2 Replies 2
David Maudlin
Tom:
Under All Parameters > Frames > Bottom Rail Width. In AC19 this parameter has been added to the Shape and Panel Divisions... panel.
To use a Curtain Wall, just add an Empty Opening (Simple Window Opening) to the Wall, then place the Curtain Wall in the opening, which is my preferred method.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Tom Krowka
Got it. Thanks.
Thomas@wkarchwk.com
www.walshkrowka.com
