Generate IFC entities from GDL?
That would be great to be able to generate IFC entities from a GDL object.
In that way we would bypass the need for GDL to generate native archicad elements.
A GDL object would be able to generate IFC slabs walls etc.
Now an object can be exported as an IFC entity, but that would be great if placed objects inside the main object( Macro calls) could also be exported as individual IFC entities.
I will post that in "wishes", but maybe someone knows if it is already possible?
4 Replies 4
Erwin Edel
So for one object to have multiple IFC entities attached to it's individual parts?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Essential!
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
@Erwin : yes exactly
Mario Sacco
It should be great! I developed a railing with a automatic wall. I'd like to export two different IFC entities. Please let me know if you have any idea to solve this problem and if GS is planning to implement this feature.
Www.3dmediadesign.it
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
