strip footing under wall
Aussie John
I am looking to code a strip concrete footing under a masonry wall. I asssume that using wall accessories is the way to go.
Any suggestions as to where to start? I have tried making a block (or a prism) but not sure how to call up the length of the wall.
Cheers John
[/size]
vfrontiers
John,
The only way to READ the attributes of other AC elements into an object is thru the API technology.
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
i have made some similar objects by modifiyng the archicad wall-accesory
object, to put only a beam at top of walls and doors & windows
and not the entire wall wood frame.
I also derivated other roof accesory objects.
the addon (*.apx ) only put the corect values in object parameters (coordinates, etc) but all the accesory objects are just objects - gdl
depend of you needs and imagination to put at work the apx capability to give automate values to this objects.you must study the archicad original gdl code and try to modify . ( ac_coords... etc) you will see..
dont forget to save by correct subtype library .
if a skylight object is not saved as skylight subtype it will not work because the skylight.apx will not recognize them.
in your particular case i sugest to keep only the base beam of
"Wall Framing.gsm"
Aussie John
thanks Archibaldo- using the stud wall is a good idea.
Cheers John
[/size]
