turn off 2D hotspots in 3D
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2011-04-07 12:52 AM
It's my first post here. Hope not the last one.
I'm working on my own GSM object, which I make by saving model from ArchiCAD and add some GDL scripting.
I've found that hotspots, which I drew in 2D symbol appear in 3D model. Is it possible to turn them off? They're really messing up the symbol as I use own 3D hotspots.
Thanks in advance for reply
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-07 03:34 AM
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-07 03:22 PM
Today I've found something funny: ArchiCAD v13 x32 (today updated) displays those 2D hotspots in 3D while ArchiCAD v14 64bit doesn't. That's weird...
Any other ideas?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-07 04:03 PM
Jezyy wrote:Jezyy, does this happen for all objects or only for this particular one?
Agree, I turned it off before asking question here - it didn't work.
Any other ideas?
bT Square Peg
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-07 11:22 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-07 11:50 PM
check registry or special menu to reset .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-08 11:19 PM
Nope, it doesn't work.
So, what do you mean archibaldo by check registry or special menu?
My system is fresh and everything is installed recently with default settings.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-09 02:04 PM
This is what worked for me in AC 13:
1. As vistasp said, turn off the Showing 2D Hotspots in 3D parameter.
2. Add Hotspots to the 3D Script (if there are no Hotspots in the 3D Script, then the 2D will be used)
3. Under Details..., Hotspots on bounding box should not be checked (I think this is a difference between 13 & 14, does not seem to matter in 14)
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-09 10:57 PM
You might want to try placing a new instance of the object to see if that helps. Changing the default setting of the Showing 2D Hotspots in 3D parameter in the parameter table will not affect instances of the the object already placed.
Alternately, unhide this parameter so you can change it in previously placed instances.
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-04-14 08:03 PM
I did as Erich said - unhide "Show 2D Hotspots in 3D" parameter. It turned out that in the object placed on the plan kept this parameter as ON despite of beeing OFF in the script. So now the object displays 3D hotspots I've placed in 3D script (both movable and static).
Best wishes
Jezyy
