using WALL_DIRECTION in a door/wdw marker?
any thoughts or ideas how i can use the WALL_DIRECTION parameter in a door/wdw marker to adjust the positon of the marker relative to the outside of the window its lableing???? I've noticed that depending on the direction i draw my walls, the label jumps to one side or the other.
can I somehow request the value to use in adjusting marker?
thanks,
Dan K
0 REPLIES 0
