GDL Object(Door) Visibility in Floor Plan
After creating the GDL object (Door) and placing it, the door is getting placed but appears like a window in floor plan. The door swing is not showing in the floor plan. Where as the view of the GDL Object (Door) is perfect in elevation as well as in 3D view.
Any help will be greatly appreciated.
2 REPLIES 2
David Maudlin
suresh_rcms:
How did you create the door object? If it was created by saving from the 3D window, then you are seeing the top view of the door. To change this 2D view you will need to open the library part and change the 2D Symbol using the 2D drawing tools, or using the 2D Script if you want the 2D symbol to be parametric.
Hope this helps,
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Hi David
I got solution with ur reply.
Thanks a alot
suresh
